injectors what size
Car: 89 iroc
Engine: 383 tpi
Transmission: t5
Axle/Gears: 327 9bolt
injectors what size
I believe I am in need of new injectors?
I have 45psi at rail and noid lighting up when cranking on all injectors all 8 have 14.3-14.4 but wont fire up
I can fire it with a can of fluid but dead after that's gone
pulled a few plugs and they dry as bone after cranking doesn't even smell a tiny bit like fuel
does that sound like bad injectors
also when cranking psi only drops 2-5 psi and pump runs for a few seconds and needle on gage vibrates like crazy and increases slightly to get back up to 45 is that normal or due to clogging??
if I do replace what would be a good size I tried a few charts but I am not quite understanding them
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: injectors what size
Depends how heavily modified your motor is, give south bay fuel injectors a call, they should be able to set you up.
92projectcamaro
01-18-2016 08:00 AM
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
