6al box with tpi
Old 09-29-2013 | 01:20 AM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
6al box with tpi
So I just swaped my car to tpi from a carb. And am having trouble wireing the box in, in the diagram for it it only shows one red wire from the harness but two from the coil my question is what do I do with the other red wire that goes from the coil to distributor? I hooked it in with the red wire from the harness and the car runs but the tach jumps around when you give it gas? Any ideas would be great thanks.
Jesse
Old 09-29-2013 | 03:22 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 6al box with tpi
Originally Posted by kill4thril
it only shows one red wire from the harness but two from the coil.
Should have a power and a tacho wire from the stock harness going to the red and white wires on the MSD box.
Org and black wires from the box go to the coil terminals , pink and white go from coil to dist
Old 09-29-2013 | 08:23 AM
Guest
Guest
Posts: n/a
Get the "plug and play" harness. Thats what I did, no cutting or nothing.
Old 09-29-2013 | 06:54 PM
kill4thril's Avatar
Engine: 355ci
that's what I might do if I cant get it fixed in the next day or so
Old 09-29-2013 | 08:36 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You haven't answered if you have it wired up as I said ?
The MSD PnP harness just does the same " for dumbies "
Old 09-29-2013 | 09:41 PM
Guest
Guest
Posts: n/a
You mean for people who are smart, and don't want to cut theirstock harness which is old and fragile...
Old 10-01-2013 | 07:42 AM
kill4thril's Avatar
Engine: 355ci
The car runs but the tach only works at idle and when I give it gass it jumps around
Old 10-01-2013 | 07:43 AM
kill4thril's Avatar
Engine: 355ci
I thought I might hace somthing in the wrong spot and thought the harness might fix it
Old 10-01-2013 | 08:06 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Get a MSD tach adapter. Or you might be able to get away with installing a 10K resistor inline with the tach line.
Old 10-01-2013 | 08:34 AM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Where is the tach hooked up? Is it to the dizzy or is it to the box? I have a 6al and the tach line is in the factory spot(to the dizzy) and it works fine. I know if you run it to the 6al box it can be hit and miss.
Old 10-01-2013 | 09:56 AM
midias's Avatar
Mine is connected to the distributor. I think the white or gray wire.
Old 10-01-2013 | 12:12 PM
kill4thril's Avatar
Engine: 355ci
It is hooked up so that the white wire from the harness and the white wire from the dizzy both go to the msd box's white wire like the diagram shows
Old 10-01-2013 | 12:14 PM
kill4thril's Avatar
Engine: 355ci
And same for the red wires they both go to the red wire from the box and the brown tach wire out of the box is not being used right now
Old 10-01-2013 | 09:54 PM
Guest
Guest
Posts: n/a
Did you get this fixed yet?
-(white wire is not used with stock tach, fyi)
Old 10-02-2013 | 08:20 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Yes it is. Take a look at your plug and play harness. The white wire goes to both the msd box AND the tach. Some people wire the tach straight to the msd box via the tach signal wire, which I have seen has been hit and miss.
http://www.msdignition.com/uploadedF...structions.pdf
Page 14 and 15.
1992rs/ss
05-19-2020 07:02 PM
MyRedCamaro
12-29-2015 05:16 AM
The_Phoenix
09-03-2015 10:56 PM
Sanjay
08-12-2015 03:41 PM
marcusaw
08-10-2015 08:13 AM
Quick Reply: 6al box with tpi
