I 'need' 100 more hp ...
Old 09-05-2013 | 09:32 AM
EvelBist's Avatar
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
i got beat this morning by an eagle talon. it was clear he out accelerated me at highway speed, maybe a turbo. doesnt matter. the talon is about 1000lbs lighter than my car.
i'm guessing it took him taking about 8 seconds from the time i noticed him on my right to pull ahead. i know that my car is somewhere in the 375-400hp range because my 0-60 times are sub-5.
So my question is, what mods could I add to get another 100hp? I really like DIY.
current setup: ported 083 stock heads, stock valves, ported plenum and intake gasket matched, stock runners, custom chip, hooker headers, hooker 3" exhaust.
Old 09-05-2013 | 09:36 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: I 'need' 100 more hp ...
Heads cam intake
Or spray it
And those mods i dont see more than 320 hp
Old 09-05-2013 | 09:38 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Juice it
Old 09-05-2013 | 09:57 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Some talons are heavy but with AWD they launch nice. The fastest ones are about 15 flat factory. But they can be modded very easy and be quick with a little more boost.
No way your car is 375-400hp with your mods and a stock cam, probably closer to 40HP over stock if you ported things correctly. Also if you were already 400hp no way you could get another 100 with a stock TPI without forced induction.
Probably want to look into a head, cam or intake swap and retune.
Old 09-05-2013 | 10:19 AM
EvelBist's Avatar
Car: 89 Black GTA
Transmission: 700
sorry forgot to mention the CC 08-302-8.
I guess I should be satisfied knowing that I COULD build it, but there's no way without artificial methods, and just be happy with the power the motor makes by itself.
Old 09-05-2013 | 10:30 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Correct, could build it. You can have another 100 hp with new heads and much bigger cam. However tpi as it is from the aftermarket likely wont do it. Maybe a first tpi, maybe a heavily ported siamesed tpi but that all costs more than a hsr or single plane efi lol
Say you did have 280-300 whp as it sits... A good 350 can easily make 380-400 all motor just need to turn it up
Old 09-05-2013 | 10:41 AM
EvelBist's Avatar
Car: 89 Black GTA
Transmission: 700
I use the car to drive to work daily, and I'm more than happy with it. Gets good mileage too, ~19 overall.
Cost was only $1500 to add the cam, headers and exhaust. Did all the other work myself to the 100K mile stock 5.7.
Well, many thanks for the replies. It feels good to have a car that is faster than at least 90% of everyone elses, along with the knowledge it was DIY and that its just another 'lowly' SBC. I suppose the moral of the story is just be careful when messing around with japanese turbos!
Old 09-05-2013 | 11:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Just add a nitrous plate lol
midias's Avatar
Don't feel bad I got spanked by a 10 second B series turbo 1990 civic hatch. People can build really fast cars out of anything. I have seen 9 second geo metros.
Old 09-05-2013 | 12:00 PM
midias's Avatar
You are probably making similar power to this car
https://www.thirdgen.org/forums/tpi/...-stock-vs.html
Old 09-05-2013 | 12:32 PM
EvelBist's Avatar
Car: 89 Black GTA
Transmission: 700
Now this has me wondering ... the car lives at 7000' and i drive it to work (5700') in Albquerque. What would this setup be doing in say LA, Chi or Miami?
Old 09-05-2013 | 01:09 PM
Miami350's Avatar
Car: 88 formula
Engine: 305 f code
Transmission: 5 sp
Axle/Gears: 345 gears
My 88 formula lb9 5speed 345 gears and a 100 shot eats talons for lunch
Old 09-05-2013 | 01:22 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
150 shot of spray= bye bye talon
Old 09-05-2013 | 01:25 PM
EvelBist's Avatar
Car: 89 Black GTA
Transmission: 700
so if the talon has a 150 shot in his car ...
Old 09-05-2013 | 05:08 PM
Miami350's Avatar
Car: 88 formula
Engine: 305 f code
Transmission: 5 sp
What does that mean
Old 09-05-2013 | 05:51 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Stealth ram, 200cc heads, bigger cam.
Or N2O
or diy turbo
Old 09-06-2013 | 08:17 AM
EvelBist's Avatar
Car: 89 Black GTA
Transmission: 700
Originally Posted by Miami350
What does that mean
I meant all things being equal, he still wins.
Old 09-06-2013 | 09:11 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I don't understand why you say that about "if all things are equal he still wins". By that logic, you should have a turbo, since the Talon does.
100 shot will not affect drive ability, gas mileage, etc and give you MUCH more power when you need it.
It's not "artificial" when you're spraying, trust me.
Old 09-06-2013 | 09:19 AM
midias's Avatar
And he should have a V8.
Stock for stock though a 1990 turbo talon will take a thirdgen 5.0
Old 09-06-2013 | 09:24 AM
EvelBist's Avatar
Car: 89 Black GTA
Transmission: 700
The way I see it is the car comes from the factory with or without a turbo. My car didnt. Adding a cam, modding the heads or intake or exhaust doesnt change the essential factory version of the car but adding a turbo would. I suppose putting a high compression, 106 LSA cammed, stroked 454 in my car would fit my logic though
Old 09-06-2013 | 09:37 AM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Or a junkyard 4.8/5.3 LS with a 76mm turbo. Forget big blocks unless its for nostalgia or all out crazy (1000+hp) builds.
Old 09-06-2013 | 10:19 AM
Car: 1971 Camaro
Engine: 427
Who cares what was stock or not?
We're not building a stock eliminator class car here.
Old 09-06-2013 | 10:20 AM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Talon vs camaro is two different cars made for different markets. Face it are cars are slow, with out straying away From O.E. your car will stay that way. The cheapest way is nitrous a stock car can take 150 shot all day. And your intake prevents any quick high speed fun.
Old 09-06-2013 | 11:11 AM
Car: 1971 Camaro
Engine: 427
I'd check that 25 year old stock engine out real well before spraying it much.
Old 09-06-2013 | 12:06 PM
Sojer's Avatar
I know guys using 150 with tires only thing that broke was his rear end. 305 t5 combo
Old 09-06-2013 | 12:08 PM
Sojer's Avatar
But its a good idea to check out over it nore would I just just jump into 150 shot. 50 and go up
Old 09-06-2013 | 01:32 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
nuff said
and who cares? it was a talon, if you are that hard up about it change the car. sure some imports are quick and civics too, but they are just that a civic... my girlfriend drives a nice one everyday...
if you want to go fast with these cars, drop a ton of money into them, because once you make the engine fast, then you need to beef the tranny, then you need a better rear cause you don't get any traction with street tires and add drag radials and blow it....the list goes on my friend...
you decide where it ends.
Old 09-06-2013 | 02:07 PM
crafty_z28's Avatar
Car: 87 Z/28
Engine: 5.0L
Axle/Gears: 9 Bolt posi
I agree with most said here, spray it.
Some talons are pretty deceiving, I bought one a while back as a winter car (Turbo AWD, why not!?) Ended up doing a full exhaust, bigger turbo (Evo3 16G), a few little things like intake, intercooler, fuel, and a dyno tune. Car made almost 350 to the wheels, and I managed a best of 12.2 in the quarter, even tho my 60ft could have been better. Those cars can sneak up on you pretty easy if you get someone who is serious about them and not the bright a$$ green POS in "fast and the furious" lol
Old 09-06-2013 | 02:32 PM
Sojer's Avatar
Yes and the same for bolt on performance bigger cam needs a long list of parts to make it perform right
Old 09-06-2013 | 05:24 PM
GenX'Motorsport's Avatar
Car: 1989 Trans Am WS6
Engine: SBC+TPI+BOOST
Axle/Gears: Eaton 373
You have full exhaust. Put in a nice cam, bigger injectors, work the intake a bit. And add some boost. Then smoke that Talon!
Old 09-07-2013 | 11:22 PM
Sojer's Avatar
How far modded the talon is?
Old 09-11-2013 | 09:27 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Old 09-11-2013 | 09:54 AM
Guest
Guest
Posts: n/a
I sprayed my 88 L98 (bones stock and unopened ever. What happened is the cylinder pressure took out the original head gaskets. My fuel pressure gauge showed that the pump was fighting an uphilll battle to a certain degree. My motor has seen about 40 lbs. of "bugger sugar" and is till going strong.
-I was hooked on my second button hit and I was spraying it daily. (esp while merging on the highway from work)
--I was emptying out a single 10 lbs. can every 3 days and id have to wait till payday to get "my fix" (I eventually converted my setup to a dual 10 can setup...before selling it all)
---Never got to race anyone or go to the track with it.
Finally you: WILL NEED:
A full tune up
A perfect running motor (pref L98)
Headers (as your cylinder pressure will be sky high with the logs holding you back)
Biggest and longest you can get. (pref 1 3/4" LTs - 3" collector)
cat back
A good flowing muffler or better yet (keeping cylinder pressure in mind) a cut out.
93 oct. or better
A very long prayer
money
time
more time
bottle heater
blanket(s)/ insulator jacket(s)
pressure gauge (pref. electric)
110% perfect working cooling system (...lol...I couls tell the smack was working -good- by the water temps with the stock config....)
The trans is will have to be "kept in mind"
depending on your traction situation...SP mods
tires
(no hard launching on that 10 bolt either...)
Thats about it...
-electric fuel pressure gauge and I would like to throw in: MSD part #8xxx Blaster coil (not the stock replacement coil, which dose nothing better) AND an MSD 6AL Digital box. To "light the night away"
-Lastly even more money
Old 09-11-2013 | 10:13 PM
Sojer's Avatar
Too much air flow can lower torque if u dont go up in cubes. With a stock l98 lets say 250 hp he would make only 400 to the crank. He wont need headers that holds 800 hp. And headers that big cost more than the whole set up plus engine with prices just under 2000.
Old 09-11-2013 | 10:38 PM
EvelBist's Avatar
Car: 89 Black GTA
Transmission: 700
A full tune up
cat back
93 oct. or better
A very long prayer
money
time
more time
bottle heater
tires
Thats about it...
one more thing - beer.
Old 09-11-2013 | 11:00 PM
Guest
Guest
Posts: n/a
My coated 1 3/4 - 3" LTs cost me $385....air flow wont hurt anything, he will need EVERYTHING that I listed if he wants the power and be able to use.
Old 09-13-2013 | 10:17 AM
Miami350's Avatar
Car: 88 formula
Engine: 305 f code
Transmission: 5 sp
My 88 formula with full slp pack lb9 5sp 345 gears and that almighty 100 shot hangs with a lot of modern cars light to light no prob 13 90s to 14 20s
Old 09-13-2013 | 02:51 PM
Tx 91Z28's Avatar
Car: 91/Z28/69SSCamaro/72Cheyenne
Engine: 350/350/350
Transmission: 700r4/400/350
Axle/Gears: 3.23/4.56/4.11
Just spray it ... enuff said
Old 09-13-2013 | 04:47 PM
Miami350's Avatar
Car: 88 formula
Engine: 305 f code
Transmission: 5 sp
Ditto
Old 09-14-2013 | 07:11 PM
Sojer's Avatar
Where u get them headers from. Most comp headers are 800 plus. Add custom y pipe o2 bong welded on. Try to put a single plane intake on a 305 see how u move off the line
Old 09-14-2013 | 11:38 PM
racerx520's Avatar
i think eagle talons are turbo from the factory. a friend had one, it was pretty quick, i've been beat by a 2008 V6 mustang, and the other day while my pedal was mashed trying to get away from a 98 dodge 2500 "rolling coal" i was ousted....then again i have a 305 tpi too...
I agree, best bang for your buck it seems here from what everyone has said, cam and heads....intake runners too
Old 09-15-2013 | 09:46 AM
  #42
Axle/Gears: 4.11
Throw the TPI in the trash
hectre13
Car Audio
26
03-03-2022 05:38 PM
Pac J
05-17-2020 10:44 AM
Mark_ZZ3
05-24-2018 01:02 PM
383backinblack
10-14-2015 08:50 PM
Royal_Z
09-30-2015 08:45 PM
Quick Reply: I 'need' 100 more hp ...
