FORD injectors
FORD injectors
I have a chance to get a set of Ford Injectors E5TF-A3B. I was told the number is on the injector that were bought for a 5.0L Mustang. They are the fat body similar to the GM TPI except yellow top (not orange) with black body. I searched the web but the Ford number got no matches.
Can anybody help find some info on them, like LBS @PSI. The TPI injectors are supposedly 19LBS@43.5psi.
Thank you in advance.
Re: FORD injectors
Like these ? Bosch 2 it will have a 028 number wich is the part number. The for 19s at 3 bar flow 22#hr.
http://ontario.kijiji.ca/c-cars-vehi...AdIdZ510139966
Re: FORD injectors
Ya, that's exactly the ad I'm looking at. He's going to look for more numbers. Do you know the info from experience, because I could not find anything on the net. If so, where?
Thanks TP.
Thanks TP.
Re: FORD injectors
Once you get another part number you might check with Southbay08 injecter experts extraordinaire ? I do know for a fact the 5.0 fords are not rated at 3 bar in the 5.0 . The increased pressure will increase the injector flow. You just never know what your going to get with used injectors. Its worth the extra cash to go bosh threes that are ohmed and flow tested/cleaned.
http://www.megamanual.com/v22manual/minj.htm
