pro comp heads
1 Post
Car: 91 gta ws6
Transmission: 700 R4 TRANS
pro comp heads
Question
are there any 3rd gen owners that own a set of pro comp aluminum perfomance heads .If so what type of power are they helping create on the 350s or 383s.I plan on converting my l98 350 into a 383 efi sbc.I have been looking at the pro comp heads.the 210cc in particular but i want to know in general are the guys that are using the comp pro heads are you guy having great success with them before i buy them,also
how is the casting quality have they improve since the first time they came out.
are any of them efficent enough to support 500hp on a single plane efi 383 without needing to get them port and polished.
any feed back would be greatly appreciated
![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
1 Post
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: pro comp heads
I've done some research and think the Procomp aluminium heads would work well on my L98 350 when I rebuild it.
From what I've read, the Pro Comp castings are good, but the valve gear is pretty cheap.
I was thinking of buying a pair of Pro Comp heads from Skip White, who buys the bare heads and adds better valve gear.
Seems like the Pro Comp heads are a Chinese copy of the Edelbrock heads.
1 Post
Car: 91 gta ws6
Re: pro comp heads
yea i was looking at those heads from his store also.and they seem like they are good,I plan on changing my 350 l98 to a 383 and use a single plane efi intake.
ambainb
04-25-2016 09:21 PM
gixxer92
09-01-2015 04:32 PM
mz92274
08-25-2015 08:47 AM
