Valve Lashing
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
Valve Lashing
I followed the book on how to lash (adjust) my valves, tightening the rocker arm nut. And, I can freely spin some push rods but not others, is this bad?
Also I lost a rocker arm nut, can i just use any nut?
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: Valve Lashing
Yes they can still spin (some might some might not dont worry about it) shouldnt be able to wiggle them up/down though
Re: Valve Lashing
If some valves are open and others closed, depending on which cylinder you look at, ofcourse some will spin because no spring load on the pushrod.
When you do the method for adjusting lifter preload, (not lashing valves because hyd cans dont have lash) you generally want to set preload at 1/2-1 turn past zero preload or refered to as zero lash where pushrod starts to have resistance when you try to spin. After adjusting near 1 turn more the pushrod should be tight. However after rotating motor over a few times to set other lifters/rockers, when you come back to the first one you did, they may feel loose again. Thats just lifter bleeding down and is normal
Re: Valve Lashing
Alright thanks for the help, came back to do it again the day after and i guess the lifters settled as someone said and they could spin but not move up and down. Thanks again!
355tpipickup
09-13-2015 11:35 PM
dimented24x7
09-06-2015 03:51 PM
