wanting to change my computer system
Car: 1986 iroc-z
Engine: 350 tpi.
Transmission: 700r4 with shift kit
Axle/Gears: stock gearing
i recently put a 350 in my 86(Which used to be a 305) TPI and im using the old computer from the 305 but the guy i bought the car put the stupid hypertech chip in it thats supposed to increase horse power but doesnt do anything but use more fuel and thats why im wanting to change the computer and get rid of the chip. and was wondering if this would work in my car ?
http://www.partsgeek.com/gbproducts/...FQmFnQodfnsAjA
Re: wanting to change my computer system
The link you posted is to the same ecm you already have . The 1227165 was used on tpi maf 86-89. The calibration memcal needs to be replaced or reprogramed. If you want to tune it w
Yourself with a flashed based system look into dynamic efi ebl p4.
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
+1. The ecm is the same between the 305 and 350. The difference is in the Memcal/programming used by the ecm.
Car: 1986 iroc-z
Engine: 350 tpi.
ok i need to buy a new one because the hypertech chip is what i want rid of, ive heard of it messing with gas mileage and mine is just getting worse. and every little bit helps and for future posting just removing the chip wont help, when you take the chip out the car wont start so i need a new computer.
Car: 1986 iroc-z
Engine: 350 tpi.
the computer system in the car right now has this chip in it http://www.jegs.com/i/Hypertech/533/...FQ6EnQodrTAAnQ
which what ive read around is supposed to help HP by messing with the air flow and fuel mix ratio but in simple terms everyone ive talked to it doesnt do anything but dump more fuel into the motor. which if it doesnt help my HP i dont want it on there if its wasting gas. now as stated above when i try just removing the chip from the ECU it will not start so ive been told to just buy another ECU and put it in
I assume you went with 22#hr injectors for the 350?
There are several hypertech some were oem memcals that were reprogramed, some were made for hypertech and have a black goo over the circuit board and a small chip under the eprom ( these cannot be reprogramed ) and a piggy back board that attaches to the oem memcal. You maybe able to get your memcal reprogramed depending on the style. You can use any tpi 350 automatic broadcast code from 86-88 but the 89 is a better definition but has vats enabled.
The ecm thinks you are running 19#hr injectors and controlling the pw accordingly but if you were running 19#hr injectors on a 350 with a 305 memcal you run too lean and have over heat issues. When you run 22#hr injectors on a 350 and use a 305 memcal you run really rich.
Car: 1986 iroc-z
Engine: 350 tpi.
kept the same injectors from the 305. but they arent stock but were used in the 305 they are weird looking(ones i havent seen) they have 3 holes in the end instead of 8 or 9 smaller ones?? now im not an expert in fuel injectors or anything but it was something that the guy that put my motor in has never seen before. i was wondering if that had anything to do with my worsening MPG
Car: 1986 iroc-z
Engine: 350 tpi.
http://www.automotix.net/usedautopar...0d1a&seq_num=6
would that be the one i need??
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The ECM's are identical ; as you have been told above only the chip / memcal / prom ( whatever you want to call it )that has the tuning info is different to suit whatever engine the ECM is controlling.
All you need is a memcal for a 350 to replace whatever chip is in it now
Car: 1986 iroc-z
Engine: 350 tpi.
You not getting it are you?
Car: 82 Z28
Transmission: T400
And given it states the ECM suits both 305 and 350 engines, most likely it comes without the memcal as most ECM's do ( you are supposed to refit your existing memcal ) so you would be no better off
In any case $50 -$75 is a more common price for a used '165 ECM that you have
http://www.ebay.com/itm/86-89-Corvette-ECM-88999194-Latest-Upgrade-replaces1227165-16198259-Perfect-/190813213033?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c6d5a9169&vxp=mtr
Car: 1986 iroc-z
Engine: 350 tpi.
i can probably snap a pic of it tomorrow, and is this what you were talking about replacing the hyertech chip with ??
http://www.ebay.com/itm/1987-350-TPI-Camaro-Firebird-Automatic-Computer-Chip-Memcal-PROM-ABWN-/360585764384?pt=Motors_Car_Truck_Parts_Accessories&hash=item53f4961e20and would adding the 22Lb injectors help my MPG any at all?
Car: 1986 iroc-z
Engine: 350 tpi.
well the motor came from oreilys its brand new and its what would have gone in an 87 camaro so everything is stock like cam wise
On tpi maf 86-89 the memcals are all the same it's just the calibration programing that is different between automatic, manual 305, 350. The can be reprogramed or there are several guys who are parting out thirdgens in the classified section here.
http://www.gearhead-efi.com/BCCFind/
9192camaro
16
02-03-2019 12:21 AM
