what camshaft do u recommend for my 305 tpi
Car: 1987 trans am GTA ws6 package
Engine: tuned port injection 305 5.0
Transmission: t5 5speed manual
Axle/Gears: 3.08 i think
my plan is to add a air intake, then port my plenium,runner,manifold,and throttle, am also thinking of adding a cam while am at it but it dont know which one to go with i want a mild cam or stage one i dont want it to big, i found some on ebay but dont know if there good for me engine which is mostly stock and i heard lunati is a good brand also!! help please and thanks
specs of the lunati cam
APPLICATION CAMSHAFTS
VALVE SETTING
RPM
OPERATING
RANGE
CAMSHAFT PART NUMBER
CAM GRIND NUMBER
DURATION
VALVE LIFT @ 1.5:1
LOBE SEP. ANGLE
ADV.
@ .050”
IN. EX. IN. EX. IN. EX. IN. EX.
HYDRAULIC FLAT TAPPET: Mild rough idle. Great for street machines/muscle car. Largest cam for stock torque converter, best with 2000+ stall.
Hyd
Hyd
2000-6000
10002
NA
272
280
224
234
.465
.488
112/107°
VALVE SETTING
RPM
OPERATING
RANGE
CAM GRIND NUMBER
DURATION
VALVE LIFT @ 1.5:1
LOBE SEP. ANGLE
ADV.
@ .050”
Hyd
Hyd
2000-6000
10002
NA
272
280
224
234
.465
.488
112/107°
Re: what camshaft do u recommend for my 305 tpi
and gonna run some long tube headers
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
if you car is the original 87 motor it should have a roller cam and that cam wont work. If you have the peanut cam id swap in the lt1 cam. If your car has the l98 cam i would look into a crane 2032.
oh ok thanks i was told not to go with a LT cam cuz theres not much difference, i want my car to be a lil louder and also get a good gain of hp? but ill check out the crane cams thanks
What headers and exhaust will you be running? I ran a Comp 210/220 .480/.480 112LS cam back in my 305 days and had great success. I'd suggest the exhaust upgrades and a 3.73 gear as well!
am planning on running longtube hedman street hedders and right now i have no muffler it ends at the cat, i cut it off when i replaced the fuel pump cuz the pipe was rusted and no good, but i think am going to go with a SLP loud mouth.. i heard the 3.73"s are no bueno for the 5spd 9bolt, cuz my tpi will run out of power at high rpms?
have u guys heard about this cam? Crane Compu cam 2010<---
Car: 87 Camaro Z28
Engine: TPI 350 bored .030 over
F-Body's love 3.73's. It'll make a night and day difference in performance.
yea thats what i heard that 3.42s are big enough cuz 3.73"s u wont have no first i like my stock gears cuz even on take off my car has to many torque i want a smooth launch with alot of mid range and top end power
Definitely not true! 3.73's are perfect choice for most manual street/strip TPI applications! I first installed the 3.73 gears with posi back in my 305 TBI days and knocked off a half second in the 1/4 mile. That first time I went to the track blew me away how much of a difference it made. I thought it was a little bit steep at first but you get used it in no time. Once I switched over to TPI, added a lil cam to the 305 and few other small things, the 3.73's were a perfect choice....And still today with my current setup 355 setup! Remember, you want to be at the top of the gear when going thru the 1/4 as you want to maximize the use of the engine power. Good luck!
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
1 Post
Axle/Gears: 3:42
I'm telling you, when I had 342's on my bolt on 350 TPI , first gear sucked. I can't imagine how a 373 would be. I was also running bigger tires too
1 Post
Axle/Gears: 3:42
The questions should be, Where are your rpm's at with the 373's when on the highway and how did you like it? and how bad was your gas mileage
thanks and am thinking of doing some porting my self to get some more air flowing in the top end!! and nice times
If I recall the rpms increased 4-500 rpms at 70mph vs the stock 3.08gear. I chose to hop the car up for performance not mileage. More extensive mods to a car will decrease mileage some. Cam, heads, intake, gears.... it will all effect mileage. Overall with my current setup I still managed 22mpg on a cruise from Baton Rouge to Memphis once for a race. Ran my best times of 11.6's and drove back. The thing with the lower gear is you will be able start off in 2nd from a stop easy just like before in 1st. You can skip gears and use 5th more in town without the lagging. You have to use the gear to your advantage when driving it so mileage isn't effected much at all.
Was this with an Auto or Manual that you had? For an auto TPI car yes, a 3.42 might be a better choice. Especially with a looser torque converter. But later on with a higher rpm range more gear will be required for optimum performance.
1 Post
Axle/Gears: 3:42
With a 3.42 gear and my 700r4 and bolt on mods , I averaged a little less than 12mpg around town.
1 Post
Axle/Gears: 3:42
A 373 may work ok, if you have a manual. Probably worked ok for you cause you were not using the stock tpi setup. Which likes to make it's power lower in the powerband.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I don't know if you've decided on the camshaft yet or not, but www.camquest.com is a decent little site. That's Comp Cams online engine dyno and camshaft selection tool. It would probably give you some ideas of what you want for a camshaft size. It's pretty detailed too for a free tool. You can adjust head characteristics, intake, valve sizes, exhaust, and etc.
My stock 350 TPI with bolt ons nothing internally done would get 17/18 MPG with 700-R4 and 3.27 gear with a 2400 RPM 9.5" lockup converter. I also agree 3.73s might be a little steep depending on your setup. Also remember gear swaps can get expensive between the labor, gear sets, install kits, and etc. You could easily get $400-$600 wrapped up in it. If you have a 9 bolt you will have a hard time finding anything other than the normal 3.27s or a 3.70 noisy gear in the US to swap too, unless you order from AUS.
I would still use a 3.73 gear with a manual trans behind a long tube runner setup any day. Who ever plans on keeping their TPI stock though? Everyone is always looking to increase the rpms and power.
yea am not trying to run a all raced out motor, just a lil tweak to hit the races up and also cause i rather swap in a ls2 then spend alot of money on a tpi that is hard to reach more then 400hp without having to buy a bigger block or stroking it out
Car: 87 Camaro Z28
If I remember right my t-5 and 3.73 gears didn't even make 3 mpg difference. It seemed to put more torque where I used it most so the engine didn't have to work as hard. It's not a big sacrifice over the gain in performance.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
3.73's is only good for is getting off the line and thats it. You can't rev the engine pass 4800 anyway. 3.73's work best if the engine is making power 6000 plus. Anything below that 3.42's works the best because it will give more mph. Don't be fool by the quicker acceleration.
Sanjay
08-12-2015 03:41 PM
