a little question about the tpi itself.
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
i see people all over here having 355's,383's and such having tpi setups on them.. which engines will fit tpi systems? can i just buy a random chevy v8 block and put a tpi on it? even a pontiac 400? is there a year range?
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Re: a little question about the tpi itself.
There really is no simple answer as in will any block work in my car because not all blocks have all mounting holes drilled and tapped and some blocks don't have the lower oil passage near the oil filter which some TPI systems use for the oil switch. but you can make them work. One reason why so many hot rodders use the TPI set up is that it can be used over a bunch of different applications.
even a pontiac 400?
Car: 88 iroc
Engine: 305 tpi
Transmission: unknown atm
Axle/Gears: unknown atm
Not to hijack the.thread but i was told vortec blocks will work and vortec heads but in my reading ive found out that vortec heads have a cross flow cooling system. So whats the truth as im completey stupid when it comesvto this or that will work
Axle/Gears: 3.47
this isnt up for hijacking.. if anyone wants to take over they are more then welcome to haha.what cars in the late 80's(i have center bolt heads n a 305) had 383 and 327's?
NOT STRICTLY TRUE
http://www.chevroletperformance.com/...8772&engCat=sb
http://www.chevroletperformance.com/...9101&engCat=sb
and the 400 pontiac is a totally different engine than a 400 chevy, the TPI will fit MOST first gen SBC engines with NON-vortec heads and yes there are VORTEC base intakes to convert the TPI to fit VORTEC HEADS
Engine: 4++,350 & 305 CIs
http://www.jegs.com/p/Chevrolet-Perf...69813/10002/-1
Axle/Gears: 3.47
by 400 crankshaft do you mean a crankshaft from a 400 motor? isnt that a bigger motor then the 350?, so wouldnt that be alittle to long for a 350?
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
That is the point to make the stroke of the piston to travel farther taking in more air an building more compression to make bigger hP an tq numbers there is some machining u have to do to the block so the crank journal clears from hitting the block but it can be done
NOT STRICTLY TRUE
We're not talking crate engines, we're talking factory cars. I am aware of the ZZ383, we put one in a '63 Corvette here at work a few years ago.
Engine: Broke - 350
A good die grinder and deburring bit can knock that out right away.
Here's a good article on the 383 SBC's
http://www.carcraft.com/techarticles...y/viewall.html
Sanjay
08-12-2015 03:41 PM
