Weiand stealth ram Tpi intake: can you modify your stock fuel rails to work?
Car: 1987 IROC-Z Z28
Axle/Gears: 3.70 9 bolt
Im trying to figure out if I can use my stock tpi fuel rails with the weiand intake? They want 250$ for the holley rails they rec.!
Thanks guys
Thanks guys
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: Weiand stealth ram Tpi intake: can you modify your stock fuel rails to work?
Do not believe its possible. Edelbrock victor rails will fit for 90 bucks but you need all the fittings and cross over stuff plus external regulator. Likely approach 200-250 bucks all said and done depending what you get
I think Im going to just buy the intake and see. Ive seen people modify the stock rails and add fittings. I guess ill find out. Im ordering it tomorrow. Ill post results and pictures( if modification is possible.
Car: 89 Iroc-z
Transmission: TH400
Its just mounting them to the base thats gonna be the problem. THey dont have holes thru the rails to bolt to the bosses on the base.
So the injectors line up, i can weld new mounts onto the stock rails?
Also modify ( install fittings and make lines, including the regulator).
I guess I will know when I get the manifold.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If you can make it work the stock TPI reg will be no use.No room for the crossover tube and reg on a HSR
It looks like there are much cheaper rails you can get. I think Im going to get procomp rails. Looking at regulators now
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
So follow up please what all did you need to make the stock rail fit? Pr what was the pne you decided to go with?
Car: 82 Z28
Transmission: T400
9192camaro
16
02-03-2019 12:21 AM
L98GTA87
08-11-2015 06:55 PM
