88 TPI into a non vats trans am?
Car: 1983 Daytona 500 Edition Trans Am
Engine: Carb 305
Transmission: NWC T5
Hello everybody,
Im putting an 88 tpi setup into my 83 non vats trans am. Do i need to do any bypass wiring to the computer? Im not sure if 88 was a vats year. Also is there any special wiring i have to do to incorporate the 88 wiring into my stock 83 console wiring? thanks P.s. i tried to search, but i didnt exactly know how to word my search so it would show the results pertaining to my problem.
Re: 88 TPI into a non vats trans am?
No VATS til '89. You're safe as far as that's concerned.
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
The biggest question as I see it is the C100 connector. Will it need to be repinned? Get a wiring diagram of both 88 V8 TPI and your original 83 C100 connectors.
I seem to remember finding wiring pinouts on here somewhere for LT or LS swaps. That is where I found out about mine.
Engine: Carb 305
thanks for the reply. Thats a weight off my back. I have everything else i need for the swap. So im just gonna have to sit down with a wiring diagram and the harness, and get it all sorted out. Thanks again
Engine: Carb 305
one more question. Are there any companys that make a prom with vats deleted?
Engine: Carb 305
I completelly forgot that. Im at work, so it just went over my head lol. thanks
beachrodder
08-25-2015 08:05 AM
Sanjay
08-12-2015 03:41 PM
