injector size ?
Car: 89 iroc z
Engine: 353tpi
Transmission: 700 r4
Axle/Gears: 342
injector size ?
i know the 350 tpi injector's are 22 about how much hp would u wanna change them to bigger injector's thanks
Re: injector size ?
Make sure you understand this:
Injectors should not be used at more than 80-85% duty cycle. However, injector rates are always specified at 100% duty cycle and some nominal pressure (usually 43.5 psi = 3 atmospheres). The manufacturer leaves it up to you to determine a system pressure and maximum duty cycle in order to compute the resulting flow.
A 22 lbs/hr injector can handle 300 horsepower, but if you are making that number you should be using at least a 24.... but not a 36.
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
Re: injector size ?
ok i should be fine then im thinkin im about 260 on hp right now but its an estimate tho lol how i got it is im runnin a 9.0 in the 1/8 i could be wrong tho
92projectcamaro
01-18-2016 08:00 AM
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
