Car won't start. (Fuel Pump related)
Old 06-26-2012 | 11:20 PM
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
Have an 87 Iroc LB9. Resurrecting it from a 12 year sitting period. Needed a new fuel pump so I replaced the whole tank to the 4th gen plastic tank. Worked well for a brief period of time but now I'm getting no power to the pump. I replaced the fuel pump relay today so that can be eliminated. I'm fairly certain my problem is not that the pump is seized because its fairly new, and if I were getting power to the pump, then I would either be blowing a fuse or the pump would work. I'm kinda lost as to what to do next, any suggestions would be great.
Old 06-27-2012 | 01:44 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Car won't start. (Fuel Pump related)
A guess at best
Start with the basics.
Put power direct to the pump and see if it actually runs ,if it does then back track through the pump wiring to the battery
I replaced the fuel pump relay today so that can be eliminated..
Means squat if you have no power to the relay ; either on the pump circuit or the relay control circuit
Does pump run if you jumper the terminals in the relay connector?
Do you have 12V on the pump circuit at the relay with key off?
Do you have 12V at relay on the relay control circuit with key on?
Do you have power coming out of relay to pump when relay operated?
Many thing to check
Old 07-01-2012 | 07:51 PM
Engine: 305 LB9
Solved my problem. Thanks for all your advice, you always seem to be the one to help me out with my various problems.
Old 07-02-2012 | 08:08 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
so what was it?
RazorN8
01-07-2022 11:44 AM
theshackle
03-05-2017 06:37 PM
beachrodder
08-25-2015 08:05 AM
Kaweh
08-09-2015 02:54 PM
Quick Reply: Car won't start. (Fuel Pump related)
