WHICH PLENUM AND RUNNERS CAN I USE
Car: 1989 gta
Engine: l98 350
Transmission: auto
I am looking to buy a used plenum so i can polish it for my 1989 gta 350 .I want to keep my original one on the car untouched.I know that ther were some changes through the years on the plenum and runners so which years is it safe for me to use. also was ther a diffreance betwwen the ones on a 350 or a 305 or can i use them both .thanks
Re: WHICH PLENUM AND RUNNERS CAN I USE
you can use your tb on any plenum the iac passage is open in the back. The 89-92 plenums dont have a air passage for the ninth injector. so if you go with a earlier plenum you will need to block this whole a welch plug works well.
http://www.hotrodlane.cc/PDFFILES/TPIStory.pdf
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
i got a polish plenum if ur interested ready to go 89-92runners dont have the cold start option meaning the hole for the 9 injector and and for the the plenum 90-92 are different the have the bracket for the map sensors and extra nipple for it
Royal_Z
09-30-2015 08:45 PM
