My Engine Feels slow, than normal??
Old 05-16-2012 | 11:37 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
I have a stock 1991 305 TPI
Every now and then, it seems like my 305 tpi is sluggish. It still keeps up with traffic just fine. Say Im doing around 25mph then give it full throttle it will slowly accelerate. Then other times when I give it full throttle, I feel it drop down two gears and take of with a chirp like I feel its supposed to do.
Sometimes I start the car, and it runs sluggish, other times it runs like I assume its supposed to(quick). When it runs sluggish the oil pressure seems to rest at the first tick. When it runs normal the needle is a little under half way. I assume this is causing it?
My car has a small "hint" of the smell of fuel, kind of like an older carbed car.
Any Ideas?
Old 05-18-2012 | 03:39 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: My Engine Feels slow, than normal??
if the car is running rich the first thing I would suspect is that you are still using the multi-tech injectors. I would start ohming them out. you can also when the engine is cold prime up the fuel system a few times don't start the engine and pull out the spark plugs looking for wet spark plugs.
Old 05-22-2012 | 06:09 PM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
maybe its your kick-down (TV) cable that need adjustment, sounds like its not downshifting unless you really stab the pedal
Old 05-23-2012 | 09:03 PM
Axle/Gears: 4.10
That sounds like it could be the problem, at 3/4 throttle it will down shift once, at full throttle, and I mean full throttle no less, it will drop down 2 gears. Does that seem normal?
Frozer!!!
01-19-2024 04:55 PM
Azrael91966669
25
06-20-2017 04:04 AM
bradleydeanuhl
08-12-2015 11:48 AM
flash2042
Exterior Parts Wanted
08-07-2015 05:58 PM
Quick Reply: My Engine Feels slow, than normal??
