Leaned out?
Old 05-03-2012 | 04:04 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Leaned out?
Hey guys,
I have an 88 350TPI. I started working on the air intake because its very restrictive on the engine, but im wondering if i may have gone "too far".
I took the plastic part that the air filters sit in and cut out the "boxes" that were under the filtters, opening it up big time. Noticed a big difference there! I took the "Y" intake part out and cut rectangular windows into the back of it to help it breath a bit better, noticed a difference here too. I cut the rear screen out of the MAF, but decided to leave the front one just to air n the safe side;the car is my DD and i figured it wasnt worth the minimal gain to cut that front one out too. It definetly pulled alot stronger, and the throttle respone was crisp and more powerful than ever!
I ordered a throttle body air foil and intalled it, and now it feels pretty much like it did stock, if not worse. It feels completely drained, the torque just dropped like a rock. I was really expecting it to make a huge impact on the amount of torque, but in a POSITIVE way of course. I used to burn rubber so easily, i could be going thru a corner 15-20mph and give it some gas and still break the tires free; i tried the same thing at the same turn and it didnt even break free.
Could I have made it run too lean? I thought the computer adjusts the air/fuel ratio so that it couldnt run lean though? I appreciate any imput on this.
In the meantime, im going to put the uncut Y intake back on and see if that seems to make any difference.
Thanks again guys!
Old 05-03-2012 | 04:12 PM
Black88Z's Avatar
Re: Leaned out?
I put the uncut Y intake back on and it seemed better, but still not as powerful as before.
Do I need to reset the computer (unplug battery/pull fuse) so it resets itself?
Im just a bit lost and frustrated here, i was really expecting a noticable of power gained here but instead i feel like i lost a considerable amount.
Thanks again everyone
F-body-fan
01-12-2023 01:49 PM
db057
01-10-2020 08:55 PM
Elephantismo
02-13-2019 12:51 AM
Mark_ZZ3
05-24-2018 01:02 PM
antman89iroc
36
01-31-2016 08:42 AM
Quick Reply: Leaned out?
