tps sensor
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
tps sensor
does anybody know what size the bolts that hold the tps sensor on the throttle body. my are strip out
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: tps sensor
a common thing on these.what i did was drill and tap the holes for something common ,then i made some studs and used the factory TPS hold downs and some nuts.end of problem,try it
Re: tps sensor
The factory TPS screw is a 30mm long bolt with a 4.5mm diameter and .75mm thread not a common size you can buy a die off ebay and rethread a 10/32x 1 1/4 bolt
http://www.ebay.com/itm/4-5mm-x-75-M...item19ca9dba14
Fred SS
10-12-2015 11:27 AM
