I want to delete this black thing... how do I do it?
On my L98 I want to delete that black box/mess of a thing that pretty much blocks plug access on the passengers side. Also what is it? I've seen it gone on alot of cars I just can't exactly figure out what its for? Heres a pic not a good one but you can see it. About middle ways back on the pass side.
Re: I want to delete this black thing... how do I do it?
It won't be any easier to get at your plugs after you delete that black thing.
Change them from the bottom. your hands and arms will thank you later.
From the looks of that pic, you have a pretty clean car. Don't go deleting this and hacking that....
yea the black box on the driver side i wondered about to. It looks kind of like a light bulb inside it but I don't know what it is. Its not hooked up though. I've got a set of headers that don't have the provisions for the little lines. Will I be able to use those headers and keep the air diverter.
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Putting in my 2 cents in... If you don't KNOW what it is... Don't go deleting it.
the box on the driver side looks like the horn from an aftermarket alarm system. Pitch it.
As mentioned, the stuff on the passenger side is pollution control stuff. Depending on where you live you may or may not be able to get rid of it without inspection problems. The one on my IROC is long gone, but I'm lucky enough to live in Vermont.
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Delete it! Buy some nice headers and start going to town. It cleans up the motor compartment SO MUCH! And changing plugs are really easy now lol!!
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
this isnt my daily driver so ive took out all emissions and ac and routed wires differently.. changing spark plugs are sooooo easy on my car... i can take them all out in about 10 minutes seriously...
and to tenpin.... why do you still have the heater valve... you dont even need that....
Car: 1987 Trans Am
Engine: 5.0L TPI
I did this on my IROC years ago. The only drawback is that you get a slight amount of heat through your heater ducts because there's always hot water flowing through the heater core. I never found it to be a problem and really only noticed it when I was hard on the throttle. That said, you could always install a manual shut-off in the heater core line for summer use, though I like to retain full heater functionality incase I need a little defroster in the morning.
Car: 1987 Trans Am
Engine: 5.0L TPI
what does that small vacuum line do? Did you just cap that off?
