Injectors ohm spec
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Injectors ohm spec
What are the ohms on specs on 87 305 I got 16.5 across the bored
Re: Injectors ohm spec
Well its all apart now I'm putting new heads on. But it sat for about 4weeks, I started it, it runs for about 10mins and cut off it turns over strong but won't start
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Yes this is possible, but the engine will still run with a few injectors crapped out. The probability of having serveral injectors with the exact same problem at the exact same time is remote.
No I didn't I don't have a miltimeter I used a snap on 1 at work my car would cut off on me if I tried to drive it to work. Well I have all new stuff I just don't have time to do it all I'm doing it out side in a parking lot at my apt. I only work on it when its warm out and I'm off (work 2 jobs) so that is like neveri still got 1 head to take off than its time to rebuild
They were tested cold when I start it again it will have new 1s
