TPI intake
Car: 1985 TA
Engine: 350 Carb
TPI intake
I have a 1985 TA with a 305tpi. I want to streamline the air ducting. I keep seeing pics of tpis with just a k&n style filter on the throttle body. how can i do this and if so where does the MAF go?
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: TPI intake
1985 uses a MAF sensor, so you cannot use that cool looking K&N oval/cone filter in front of the TB. Your cheap paper filter keeps your engine cleaner than an oil bath filter anyway.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: TPI intake
actually, you can mount an air filter on the throttle body by using a combination of the info in these 2 links,
http://www.eecis.udel.edu/%7Edavis/z28/ecm_swap/
http://www.eecis.udel.edu/%7Edavis/z28/ecm_swap_730/
the MAF sensor would go in the trash.
you didn't ask if it would be easy or cheap.
i agree with eseibel67, a good quality paper filter works better than the K&N filters.
Re: TPI intake
The MAF sensor was used up until 89. From 90 on, the used a speed density set up which among other things uses a MAP (not MAF) sensor, which does NOT go anywhere in the intake track, so........you can use any kind of intake you like and bolt it to the front of the throttle body. For you're purposes, no....there's no way you can remove or relocate the MAF sensor.
Very brief and super simple. Mass Air Flow senses the quantity of air coming through the sensor. Manifold Air Pressure senses the pressure insided the intake itself, if I'm not mistaken. (I'm a MAF guy, so my SD/MAP knowledge is limited)
1992rs/ss
05-19-2020 07:02 PM
LT1Formula
20
11-14-2015 12:02 AM
Sanjay
08-12-2015 03:41 PM
