Need help no start plenum full of gas
1 Post
Car: 1992 convertible camaro 1992 z28
Engine: 305 tbi 5.0 tpi
Transmission: 700r4 700r4
Axle/Gears: 2:73 2:73
Okay just had a question would a ripped fuel pressure regulator keep the car from starting it just turns over and a bunch of gas comes out the throttle body and when I took off the plenum it was full of gas oh it's a 305 tpi
Car: check
Engine: check
Transmission: check
Re: Need help no start plenum full of gas
If not, it can also be from the CCP system. If the vent and return lines at the tank get switched while replacing the fuel pump it will send raw fuel through the charcoal canister. Same deal for checking, remove CCP line from TB, key-on and look for fuel (be careful).
RBob.
Car: 91 Z28
Fuel in the plenum is a very high indication of a ripped FPR, and to confirm this you can take the vacuum line of the FPR, turn the key forward to prime the pump without starting it and fuel will shoot out of the little vacuum port.
As for it not starting I guess it could be ripped so bad that too much fuel is getting through and flooding it. Replace the regulator first and see if it fixes it. Cheapest place I found mine was Hawks for around $47 but autozone and oreillys had it for $70. I think the savings was worth the week of shipping I had to wait for.
1 Post
Yeah turned out to be a ripped diagram. Thanks for the quick replies I just received the diagram today hopefully It fixes the starting problem.
1 Post
Okay now the car just cranks but won't start seems like it's trying to start but maybe the spark plugs are to fouled
Engine: 4++,350 & 305 CIs
yup. you need new ones.
1 Post
Okay thanks guys this site is a life saver I just bought a 92 z28 for 950 trying to get it to run
Car: check
Engine: check
Transmission: check
They need to be above 12 ohms to be OK. If you get the engine running check the resistance hot.
RBob.
1 Post
Okay tried to start it with new spark plugs and just crank and pop through intake doesn't turn on the spark is very small
Check the firing order
1 Post
Just triple checked the firing order and it's correct
1 Post
I know the cap and rotor are new and so is the coil but not to sure about the ignition module or pick up coil I have a new pick up coil sitting here so I'll just install it and see what happens.
1 Post
Ok the coil checked out good, I put in a new ignition control module and spark plugs, the pick up coil ohmed at 815. I tried putting starter fluid and just back fired through the intake also while cranking there's a popping sound from the intake like it wants to start but can't and if I open the throttle it back fires through the intake I checked the firing order everything seemed right maybe the catalytic converter got plugged from the leaking fpr, the lady I bought it from said it would stall at stop lights or stop signs and one day she tried to start it and it wouldnt start just cranked over
Sounds like the timing is off. did you unhook the "set timing connector" thats over by the pass strut tower?
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Check for vac leaks and my injectors ohmed at 16.5 87 LB9 are they bad
1 Post
Got it started after cutting the cat, we checked to see where the rotor was pointing at tdc and the rotor was on backwards now it starts like a charm thanks guys
Ghettobird52
07-05-2024 11:18 PM
92camaroJoe
08-13-2015 06:07 AM
