Can you put 350 injectors in 305 ho
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Two questions
1. Can you Put 350 injectors in 305 and it run right with out over flooding car?
2. Is there anyway to go from maf to map without changing harness in car?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Can you put 350 injectors in 305 ho
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Or convert your 165 ECM to MAP
https://www.thirdgen.org/forums/diy-...f-165-map.html
