89 iroc z tpi hard to crank on cold start and when driven long distances
Car: 89 Iroc Z 350 TPI
Engine: L98 350
iroc z tpi motor hard to start on first intial crank and after warmed up and driven long distances and shut off (like to stop for gas) car has to sit a while to crank back up. installed brand new fuel pump,fuel pressure regulator, fuel filter, distributor, ignition coil, fuel sender unit to fix gas hand problem and every now and then the hand is accurate but most of the time it just sticks all the way up to F. Also, the car only takes about 6 7 8 dollars of gas at a time before the gas pump starts clicking as if tank was full of gas. Today me and my mechanic unplugged the rigged up radiator fans on my car to see if they were connected to something else and car stopped missing and stalling which it has been doing for a while now. Can anybody help me cause people are telling me knock sensor might be bad timing chain and and other bull... Thanks in advance!!!
89 iroc z tpi 350 L98
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: 89 iroc z tpi hard to crank on cold start and when driven long distances
what do u mean by crank,just turning it over or doesnt want to start but is turning over?
Engine: L98 350
wants to start but isnt turning over...sounds like it is starving for gas
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Ohm test the injectors with a multimeter. Tell us your results. Check them both cold as well as hot.
What is your base timing set at?
Engine: L98 350
ok im gonna do that today when i get off and post the results
Engine: L98 350
so i took my car down to the shop today and left it and they said that my filler neck was broke on my gas tank and something goin to the rear end was stripped or too tight and a guy had replaced my fuel lines with rubber hoses and my spark plugs werent tight so now i need
