Braided Fuel Line Question
Using a different alternator bracket which doesn't allow me to use the original hardlines so instead I have to route braided lines directly off the line from the fuel rail. What fittings do I need that will allow me to do this and where can I find these fittings and braided line? I will be connecting back to original lines further back behind the control arms. Thanks '91 LB9 305 tpi
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: Braided Fuel Line Question
recently did a intake swap to where i needed my own custom lines.. this thread helped me out alot should help you out also
https://www.thirdgen.org/forums/memb...y-start-3.html
post below is directly from the link i provided
Earl's #361-9894DBH # Fuel Injection Female O-Ring Seal 14mm x 1.5 Thread (Jegs $11.99 )
Earl's #361-9894DBJ # Fuel Injection Female O-Ring Seal 16mm x 1.5 Thread (Jegs $11.99 )
Above highlight in red is what you need so you can adapt your new AN fittings and lines
Earl's #361-AT800106 -6AN Ano-Tuff Straight Swivel-Seal Fitting (Jegs $7.99)
Above highlight in blue you'll need 4 of these straight 6AN fittings
Earl's #361-310006 AN Size: -06 (3/8''); 10' Foot Length (Jegs $52.99) - NOTE: You wont need more then 6 feet
theshackle
03-05-2017 06:37 PM
AkDrifted
08-17-2015 07:45 PM
