New toTPI
Car: 85 Z28
Engine: 355 Vortec TPI
Axle/Gears: Stock
New toTPI
Hi all,have purchased my first ever Chevrolet this year an 85 Z28 and I love it, a lot of fun to drive! As there is no emissions testing in New Zealand I am about to do away with the cat and std exhaust system including the air injection system and fit headers and build my own twin system. What I would like to know is this, when I disconnect the solenoids for the air injection is this going to affect the computer in any way and possibly bring up check engine light? If so, what do I need to do to sort this?
Cheers Simon
Cheers Simon
1 Post
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: New toTPI
No problem with removing the AIR system. No SES lights will be involved. You will need an O2 sensor in your headers to make the ECM work properly, and may need a Heated one if the location in the header is further down stream, as it needs heat to make it work.
Car: 85 Z28
Axle/Gears: Stock
Re: New toTPI
Cheers for that man, good to know that nothing will change and yes I will have to fit aheated 02 sensor as it will be down in the collector for the headers'
Thankyou
Simon
Thankyou
Simon
