stock 22lb injectors to 24lb injectors?
Engine: stock lt1
Transmission: 4l60
I need some injectors for my 93 z28. 93 came with 22lb injectors and 94-97 came with 24lb injectors. if i swapped the 24lb ones in there would i even need a tune because the engine i exactly the same. the only difference in speed density.
thanks guy!
thanks guy!
Car: 1987 Camaro IROC-Z
Engine: LB9
Re: stock 22lb injectors to 24lb injectors?
IIRC N/A 3800 - L36s use 22lb injectors perhaps those would be a cheap alternative since cars with those engines are all over junkyards.
ambainb
04-25-2016 09:21 PM
Firechicken86
08-12-2015 10:07 PM
