carb to tpi conversion 77 chevy p/u
Hi guys
I am new to the list . This is my first TPI. I removed it last week from a 1987 firebird 305 and I am installing it on a 1977 chevy p/u 4x4.with a 305 reman. i just got the intake on today and half dressed the wiring harness.
My question i have right now is I want to run a turbo 350 trans. I have two wires going to the tranny one i think is for speedo and one is for the tc lock up.do i have to use them I wont have a lock up I was thinking i might need a electronic speedo converter for the computer. I do have some electric questions I hope some will chime in .you guys have a great forum here.
here is a pic of the truck i am building for my daughter.
Re: carb to tpi conversion 77 chevy p/u
The wires have nothing to do with the speedo, they are for the lockup tcc. The speedo is cable controlled from the rear on the tail shaft. Since I believe the truck is also cable controlled you would need a speedo buffer from a camaro as they are cable driven also, although it would take some fab work to get it to work. You also might look at Dakota digital for a converter box. Since this is not thirdgen camaro/firebird vehicle I have to lock this.
86IROC112
08-17-2015 02:00 PM
Sanjay
08-12-2015 03:41 PM
350, 73, 77, c10, carb, carburetor, chev, conversion, kit, pu, swap, tpi, transmission, turbo, wires
