Fuel pump whine, fuel pressure loss and bogging bad
Car: 1991 Firebird Convertible Horsepow
Engine: 406 w/Motown 220 heads
Transmission: 5 speed manual
I have searched and not found my answer so I am starting a new thread. Hope I can get some help. Car is 1987 TA GTA 5.0 TPI 5 speed. I bought this car, sold it and bought it back. It always had a fuel pump whine but ran wicked.even though it started slowly. Then I sold it and bought it back. Now it bogs badly ,and the fuel pump whines , but it starts instantly. Ran fuel pressure check and it was low when it was bogging. Put new pump , strainer, and fuel filter. Lasted about 3 minutes , then started whining, then bogging again. Have since checked all the fuel and return lines to make sure none are clogged. Seemed like after I checked all lines that it ran good for a minute or so, then badly again. So I then replaced the Fuel pressure Regulator. No change after that. Then replaced the pump and strainer again today and it ran fine for a few minutes with no whining , then started whining and bogging. Pressure is at 30 with the car started , and if I unplug the FPR vaccum line it goes to 40. Is that about right? If I clamp the return line I get 70 or so. I am baffled and aggravated and tired. Please HELP.
Engine: 3.1 v6
Re: Fuel pump whine, fuel pressure loss and bogging bad
Did you ever figure this one out? My son's 91 Bird is doing the same thing. On our 3rd pump, the fuel filter keeps getting clogged with a brown-colored something. I thought it was bad gas the first time. Now I am beginning to think the rubber lines are deteriorating. Each time we cleaned the tank, the lines changed the filter. Keeps coming back like a bad dream.
We'll replace the lines this weekend and see.
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
You could be experiencing vapor lock with the killer summer heat and the crappy E10 gas. You are not alone, there are quite a few of us out here trying to find a solution.
I will say, your onset is a whole lot sooner than my own experience and what I have read from others.
Engine: 3.1 v6
Engine: 357 SBC TPI
I was commenting on the OPs post. However with your issue, I've read where E10 (ethanol in general) is such a strong solvent, that it could be "cleaning" that gunk from inside your tank and leaving it in the bottom for your pump to pick up. Assuming no one's dumping anything in and you used fuel injection rubber inside the tank, then ethanol maybe the culprit. The good news, eventually your tank will be clean enough to make the ethanol happy and you'd then be good to go. Just keep changing the fuel filter.
EDIT: oops, didn't notice the original post was from April!
Engine: 3.1 v6
I think I'm going to inspect the hoses this weekend. Does any one sell the factory style hoses for a car this old? I checked the regular parts places and no one had anything other than fuel line and high pressure clamps.
thanks
Engine: 357 SBC TPI
I believe in stock form, there are no hoses inside the tank. I replaced the pulsator with a piece of fuel injection hose I got from my local parts store. (you've done this a couple times, you'd know more than me)..I can be wrong
The hoses coming from the sending unit are the same. The one feed line with metal connectors, and the 2 in the engine bay may need to be purchased from either a GM store, tpiparts.net, OEHQ, GMpartsdirect.com, ACDelco.com, or something like that. Try and find the part number on those specialty hoses.
If you had rubber issues in your tank, I think the only one that could cause that would be the piece I described that I put in place of the pulsator.
Engine: 3.1 v6
I'm thinking that I'm just going to have to drop the tank and get a better pump, clean the tank and flush the lines.
1 Post
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
There is a special type of Fuel Hose for Submersion in the tank. If you use regular FI hose, it will eventually disintegrate. The special hose has an SAE 30R10 rating.
Engine: 3.1 v6
Anyone ever use a TRE performance pump:
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_4669wt_923
I talked with them, they (say) they guarantee it to be quiet.
I'm thinking about making one of these part of my next move, along with have the tank boiled and cutting an access door.
92camaroJoe
08-13-2015 06:07 AM
