Screws for underside of throttle body
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I believe 2 or 3 of the screws broke off in the holes around the coolant throttle body water jackets. Can anyone tell me what size they are?
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Re: Screws for underside of throttle body
did you get any out that are intact? they are metric and can be matched up at a hardware store. i had the same problem and was able to get the broken ones out after soaking in w-40 and using vice grips.
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
There is two differnet lenghts thier both 4mm the shorter screw is 10mm the longer screws i'm not sure of the length.
Okay, if I have to I'll pull one out of the throttle body. I was hoping I could get away without doing that so I didn't have to disassemble, reassemble, go get the bolt, then disassemble again.
If anyone happens to know the exact size I'd greatly appreciate it.
1992 Trans Am
05-10-2023 07:19 PM
mdtoren
08-16-2015 05:45 PM
