87 camaro 350 TPI
87 camaro 350 TPI
Im converting my 350 TPI to carb, and im putting an edelbrock performaer on and and a edelbrock 600 or 650 on it and was wonder what would be a good cam? The motor has been rebuild about 20000 miles ago and i want a good cam somthing that will give it more power. And im putting a set of redone 400 SBC heads on it. Im not sure what kinda cam to go with i no it has roller lifters.
Car: 87 IROC Z
Engine: 5.7
Re: 87 camaro 350 TPI
I've got the same car/engine. Mine is still tpi. I'm using a comp cams xtreme energy cam. Lift - .479/.480 Duration - 268/280. Don't know if this will work on a carb setup. I'm also running trick flow heads and ported the stock intake and put a 58mm throttle body on it. 26lb injectors and msd ignition system. You didn't really ask for all that but I figured more info is better.
Steve
Steve
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
GM Stock Cams
Model Number .05" Duration 1.5:1 Lift 1.6:1 Lift Lobe Sep. Notes
14093643 202/207 .404/.415 .431/.443 114.5 87 350,305man
10088155 179/194 .350/.384 .373/.410 109deg 87 305 auto
10066049 207/213 .415/.430 .443/.459 117deg 88-89 350,305
10111773 202/207 .413/.428 .441/.457 114.5 90-92 350,305
Sanjay
08-12-2015 03:41 PM
