help with bosch blue top injectors
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
i recently purchased some injectors off ebay. I was told that they were blue top 22lb bosch threes and that they were a direct fit. The problem is that they don't fit. Tried to install them today but they are way to short. Is there any way to make these work or should i just get a different set of injectors. any help is greatly appreciated.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Received 1,742 Likes
Re: help with bosch blue top injectors
Easiest thing to do is shave a little bit off the bosses the fuel rails bolt to.
Yes, if they are Bosch d3's and your car is a TPI you can install a second o-ring on the bottom in the groove just above the other. This will give you the extra height you need. What’s the number on the injector? If they are the Bosch D2 metal body it's a lot harder to get the o-ring on but has been done.
What type and size of o ring and you install it on the part that goes in the manifold or the end that goes into the fuel rail
What is the part number on them? Make sure that they are not 24lb denso or fms
www.southbayfuelinjectors.com
516-492-6504
hey southbay if you want you can send me those pics to footballrenzo79@yahoo.com. also what type of o rings to you use and what size. the injectors i have are pretty much all blue
ok no problem i will get to you today. Do you have a pic of the injectors along with a part number? Now i am totally
confused. 22lb bosch lll blue tops that are all blue???
here is a picture hopefully this helps. i will go out to shop and get part numbers
Those injectors are not 22lb. They are bosch lll's but they are rated at 24lb according to bosch and when they are flowtested with heptane as the calibration fluid. When we flow them with "flowrite" they come out to 26.7lb. Either way they are DEFINITELY NOT 22lb.
Is that to much injector for a stock l98. I went to your site today and figured out that they aren't what the guy on eBay said they were. been trying to get money back but no luck.
guy i bought them from just sent a link to table where i could look up the part number and its they are 22.4 lbs
guy i bought them from finaly told me he would give me my money back. thanks for all the help southbay i will definitly buying some injectors from you when i get my money back.
They are NOT 22lb. There is a post on this forum that is about 6 pages long regarding the flow rate of these injectors. What is the name of this guys company? i know that stan weiss rates them at 22lb,, but PLEASE trust me they are NOT 22lb. The yellow bosch lll's are 22lb at 43.5psi.
![burnout](https://www.thirdgen.org/forums/images/smilies/burnout.gif)
Car: 1988 Formula
Transmission: TH-700-R4
Axle/Gears: BW 9 bolt 2.77
sry to dig up a old post
I think the idea is to run the highest pressure for the best atomization
then adjust the ECM pulse.
Ford rates its injectors at a lower pressure
thus a #19 in a ford @36psi fuelrail
will transform into a #22 in a Chevy @ 43.6psi fuelrail
or something like that that is why they are a popular choice for around 300HP motors.
here is a app.
http://users.erols.com/srweiss/calcpchg.htm
Power is gained by FIRST turning up the presure and adjusting the ECM
THEN if the HorsePower is insufficient, bigger injectors are needed.
IF you just slap in bigger ones, you will STILL need to adjust LESS fuel pressure and/or a ECM adjustment. for max HP
simply going by injector color is only a starting point.
new corvettes have #65!! @???psi and run fine.
here is a app.
New2Chevy
10-04-2015 11:27 PM
Firechicken86
08-12-2015 10:07 PM
