how much are these injectors worth?
Car: 1987 Pontiac Firebird GTA
Engine: 383
Axle/Gears: 3.42 10 Bolt
ive got 4 injectors off an 85 TPI setup (from what I researched anyway) suposedly 19# injectors. Are these worth anything or should i just throw them away?
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: how much are these injectors worth?
Depends. You failed to note any numbers, pictures, or any other info that can identify the injector. Perhaps a part number? You need to explain or identify the part to know what we will be dealing with. It's like other members that say,"my SES light turns on before the IROC stalls. Please help."
My reply is usually "Pull the TC from the ALDL and then get back at me."
Engine: 383
The numbers on the side say:
5235047
Also on the edge where the power connector goes it has 648
5235047
Cool. Okay. Here we go.
1985
Engine 305 which means those injector are 19 lb
OE part = AC
OE Mfg. Part# 5235047
GM part# = 17110872
Lucas Service part = 5207002
There you go. They are old as hell. But you can store them as an emergency if one goes bad in your existing set. But if you wanna get some good used quality injectors, I recommend 19 lbs Bosch III. Good luck man.
1985
OE part = AC
GM part# = 17110872
