Cold start delete plug?
Hey guys long time fan of the site, I have a 86 TPI that has been my baby for 4 years but now is having trouble on cold starts. Either she will crank for about 5 secs before firing or just sounds like crap. Once she gets started and runs for a little while she will restart like the champ she is.
Fuel pump is not the problem and I really feel like Ive narrowed it down but I cant find a cold start valve anywhere!! The question is has anyone reprogrammed there ECM so it uses all 8 injectors to start??? Is this difficult to do by yourself??
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Cold start delete plug?
The problem might be the fuel pump relay. It juices the pump until oil pressure presuure builds and then the fuel pump will run even if the relay is bad. It will restart when warm because the fuel rail is still pressureized.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Get a prom ( chip ) from a similar spec '89 car or get a custom chip programmed with the '89 tune.
'89 was first year the injectors programmed for cold starts and the CSI deleted
When cold check to see if you have 12V out of the CS switch at front of intake to the CSI when cranking (only )
Check to see if you have 12V going to the CS switch when cranking ( only )
