L98 TPI Throttle Body Coolant By-Pass
Car: 1989 GTA
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
I'm by-passing my coolant through my throttle body and needing info if anyone knows of any business that provides block out plates to use in place of the coolant by-pass connector to the throttle body. All considerations will be truly appreciated.
Thanks.
Thanks.
1 Post
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: L98 TPI Throttle Body Coolant By-Pass
hundreds of threads on this...
just fill them, no need for a whole plate.
Car: 87' IROC
http://www.tpis.com/parts/view/27
Car: 87 IROC Z
Engine: 5.7
No need for block off plates. I did the same bypass and just got some rubber caps from Autozone. They fit perfect. You dont even need clamps to hold them on. $2 and they've got them in stock.
Car: 87' IROC
vetteoz,
Nice job. Have you thought about filling the passages to make it smoother looking?
1992 Trans Am
05-10-2023 07:19 PM
mdtoren
08-16-2015 05:45 PM
