Car starts, surges to 5000RPM
Car: 1987 IROC
When I start my car it stumbles, then surges to 5000RPM. If I press the gas, the RPM's come back down. What could be backwards to cause this. Thanks, Joe
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Car starts, surges to 5000RPM
More details on the car? What motor do you have? Mods?
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Check out your TPS idle voltage, and also how it reacts when you move it through it's full sweep, basically your looking for a smooth increase in voltage, with no voltage spikes!!
Post back with your findings!!
Car: 1987 IROC
I know the TPS voltage is .55 with just the ignition on. I'll test it through the full sweep tomorrow. Thanks for the input.
Car: 1987 IROC
**FIXED**
I am officially an idiot. There was a leak because i bolted the EGR electric wire between the runner and TPI base plate. Thanks for the help in checking other things though.
db057
08-11-2015 10:11 PM
