TPI ecu worries me
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
TPI ecu worries me
I have some ecu worries pertaining to what i want to build my motor too.
I plan to use my stock 86 TPI intake on a 350
I have a standard bore 350 block, out of a late model truck( Roller Motor)
I plan to have a 10.5:1 Compression ratio with aluminium heads.
Also plan to use a comp cams computer friendly cams. not sure which one because of my computer woes.
My problem is when my motor is all complete, how will i have to deal with my stock computer to handle the increased displacement and increase in compression ratio. i plan to go to a stand alone ECU later on done the road, but right now i need the motor to run with out it detenating and what not.
Any advice or input of the subject would be apreciated.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: TPI ecu worries me
You haven't done anything that the ECM can't handle, unless you're going to use MAP instead of MAF then you'll need custom tuning.
evilstuie
01-09-2020 08:29 PM
Sanjay
08-12-2015 03:41 PM
