ECM not responding
ECM not responding
i have a speed denisty system, the last few months the system stumbles so put a system analizer on it to see what was going on. as im driving and sometimes when i just try to start the car, the analizer reads that the system is not responding.. I have changed the ECM three times and it still is stumbling with a system not responding readout.. WHAT IS THE PROBLEM..??
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: ECM not responding
So as I said above , problem may be with wiring to ECM ( or the ALDL ground )
Check for ground on Terminal A of ALDL plug
Need to check for continuity on the ALDL wire to the ECM
Pull up the wiring diagram for your car to identify the correct wire at the ECM plug
http://www.austinthirdgen.org/index.php?pid=19
efiguy
09-27-2015 01:30 PM
