Trying to upgrade my 350 TPI Engine
Old 12-18-2010, 04:01 PM
  #51
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
Re: Trying to upgrade my 350 TPI Engine
Some people have had success using Edelbrock parts, but most think they're crap. Dyno Don makes some 1 3/4" shorty headers with y-pipe that'll work WAY better than edelbrock headers.
Old 12-18-2010, 04:20 PM
  #52
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Originally Posted by cruzplcs
im ok with 355 HP i can do lil damage with that kind of power dont u think so with a lil work on the rear gears and sum edelbrock header to make to flow better would give good push. bcuz i know bout car but cant do the work myself. lol its the cheapest way to go. one more question do i have to port the edelbrock intake and runners or just the plenum? instead of the AFR can i go with the edelbrock heads
3.42 gears cool! Edelbrock Headers ok. Dyno Don headers are the best shortys headers. SLP are second best.
Edelbrock Manifold needs major porting. Runners and plenum must be ported. Edelbrock heads really suck. They only flow about 24Xcfm. You car start with Dart Pro 1 200, Trick Flows 195 then AFR's. 195.
Old 12-18-2010, 06:54 PM
  #53
cruzplcs's Avatar
Car: 1988 Chevy Camaros
Engine: 350 5.7
Axle/Gears: Stock rearend
since i live ca its has to be smog legal and the only header I only found was the edelbrock header ill go with the AFR head thanks for all the help ill go with the 355 hp and in the long run ill go with the 383 TPI. im 20 right now so i still got a long way to go.lol ill go with the sum setup u have provided me.
Old 12-18-2010, 07:19 PM
  #54
Stephen's Avatar
Car: 87 GTA
Dyno Don will sell you his headers with A.I.R. tubes on them, but AFAIK, they aren't actually smog legal tested for the 49-states, much less for use in Nazifornia. Only like $10 extra for the A.I.R. tubes. They'll give the appearance of being legal, but no CARB # on them.
Old 12-18-2010, 07:41 PM
  #55
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Theres always a way lol
Old 12-18-2010, 08:47 PM
  #56
TGO - 10 Year Member
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
hooker 2055's should be smog legal and have a CARB number atleast I thought they did
Old 12-18-2010, 08:53 PM
  #57
VincentZ28's Avatar
Everyone with Dyno Don Headers passes California Smog. With his headers you don't have to worry about burning the spark plug wires and it's easier getting to the spark plugs. Edelbrocks headers are junk. You can't get to the plugs and you will burn the wires. Plus their headers are 1 1/2 and 1 5/8 tubes. Dyno Dons are 1 3/4 tubes. Or you can try to find SLP 1 3/4 tubes somewhere for cheap. Thats what I'm using. And I live in SoCal.
Old 12-19-2010, 12:10 PM
  #58
cruzplcs's Avatar
Engine: 350 5.7
where can i buy them i seach the net and i cant found them?
instead of the porting the edelbrock intake i can go with the big mouth system from TPIS and the Dart Pro1 200 Aluminum Heads have 64cc fast-burn combustion chamber, spark plugs located high and centered with 2.02" intake and 1.60" stainless valves and ill just bored the engine to a 355 with the zz4 cam, keith black pistons
Old 12-19-2010, 12:15 PM
  #59
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
instead of the porting the edelbrock intake i can go with the big mouth system from TPIS?
http://www.top-downsolutions.com/pro...roducts_id=170
Old 12-19-2010, 12:37 PM
  #60
cruzplcs's Avatar
Engine: 350 5.7
thanks for the link and i can use the stock Y pipe that i have now right?
Old 12-19-2010, 01:21 PM
  #61
cruzplcs's Avatar
Engine: 350 5.7
Old 12-19-2010, 01:48 PM
  #62
VincentZ28's Avatar
The TPiS Big Mouth manifold is the Edelbrock manifold with TPIS name on it. And the porting is not the same.
You can also PM Dyno Don on TGO. He's on the SOCAL board and on the Exhaust board.
Old 12-19-2010, 02:24 PM
  #63
cruzplcs's Avatar
Engine: 350 5.7
Ok thanks ill look him up. so just port the edelbrock intake?
Old 12-19-2010, 02:51 PM
  #64
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Or try the FIRST system... 1000 bucks with base runners plenum and throttlebody... thats a heck of a package deal
Old 12-19-2010, 03:49 PM
  #65
cruzplcs's Avatar
Engine: 350 5.7
what you mean the first system are you talking bout the edelbrock intake?
Old 12-19-2010, 03:58 PM
  #66
Stephen's Avatar
Car: 87 GTA
F.I.R.S.T. is what I bet he was talking about:
http://firstfuelinjection.com/
Old 12-20-2010, 02:44 PM
  #67
cruzplcs's Avatar
Engine: 350 5.7
ok i made a list on the item that im going to buy and tell me what you guys think?
700R4 Transmission, Heavy Duty, Performance, 2WD
[Part# MG302-700R4] Price: 995.00
Dyno Don 1-3/4" ceramic-coated headers, with air tubes
Price: 570.99
Single-cat Y-Pipe for use with Dyno Don headers
Price:230.00
Flex-a-Fit Aluminum Radiators
[Part# 56400] Price: 519.99
MSD SB/BB-Chevy 6AL Ignition Kit
[Part# 85551K] Price: 525.99
Holley High Flow GM EFI Throttle Bodies
[Part# 112-503] Price:357.99
700R4 Torque Converter, 2300-2500 Stall, 30 Spline
[Part# HD7730] Price: 275.00
Powermaster Alternators
[Part# 37861] Price: 199.99
AirAid PowerAid Throttle Body Spacers
[Part# 200-522] Price:141.99
Edelbrock High Performance In-Tank Fuel Pumps
[Part#17933] Price: 134.99
Optima RedTop Batteries
[Part#9022-091] Price:159.99
[Part#60859] Price:669.99
Edelbrock Victor Series Water Pumps
[Part#8881] Price:175.99
Edelbrock Touring Suspension Kits
[Part#52063] Price: 1,103.99
700R4 Adjustable Throttle Valve TV / Detent Cable
[Part#K65940U] Price: 39.95
B&M Polished Aluminum Cooler
[Part# BM-70272] [Price: 179.95
Comp Cams ZZ4 Valve Train Power Package Kits
Price:531.99
keith black pistons
Old 12-20-2010, 02:53 PM
  #68
Stephen's Avatar
Car: 87 GTA
Gonna choke all that with a stock cat-back? I see none listed.
Old 12-20-2010, 03:10 PM
  #69
cruzplcs's Avatar
Engine: 350 5.7
i have a magnaflow cat back exhaust system dual rear exit 3.5 tipsand ill just bore the engine to a 355
Old 12-20-2010, 03:33 PM
  #70
VincentZ28's Avatar
Price: 570.99
Price:230.00
Price:531.99
keith black pistons
IMO Kill the throttle body spacers, 6AL Ignition Kit, Powermaster Alternators,
700R4 Adjustable Throttle Valve TV / Detent Cable(you should already have one). Use some of that money for porting. Instead of single cat I would go with dual cats for an extra 10-15hp
Old 12-20-2010, 03:45 PM
  #71
cruzplcs's Avatar
Engine: 350 5.7
why not go with the 6AL Ignition Kit from MSD? with this mod how much power do you guys think ill get?
with posi limited slip differential with 3.42 gear ratio.
Old 12-20-2010, 03:58 PM
  #72
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Price:531.99
keith black pistons
Couple of things here....
make sure the 700r4 you buy is for an Fbody, as i think truck ones arent the same but dont quote me on that. Match the converter to the trans as well, 2500 stall is good. Make sure its lockup converter.
Reuse stock radiator from a later year thirdgen. Cheap, and work very well. Reuse stock TPI fans. Or try LS1 fbody rad/fan combo. Also a great system for cheap.
Skip MSD ignition, just upgrade the coil and plug wires and replace stock ignition module in the dizzy.
Skip the TB spacer. May even skip the TB for now. Try stock 48mm and then only upgrade if you feel like trying a new one.
Fuel pump is good idea but make sure the pump is a walbro 255 type drop in replacement for these cars. Most are. That will feed the motor
Dont need a expensive battery.
Those Dart heads are nice, but remember, thats 669 per EACH. you need 2.
If using late model accessory brackets, the water pump is a reverse rotation pump. Not sure if the victor series comes like this. Stewart makes a good pump thats designed for reverse rotation. traditional old school small blocks have a different pulley direction than 87-92 TPI cars.
Dont need a TV cable unless your stock one is missing or damaged.
B&M cooler, just get a regular black one if you want a cooler. Stock radiator cooling is more than enough for the 700r4 so you dont need an aftermarket one.
Do not by the ZZ4 kit. If you want a cam, go with someting abit bigger and use LS7 lifters if you need new lifters. Heads will have springs on them. Make sure you order the heads with a good hydraulic roller spring tho. Dart has options available. Pushrods......purchase a pushrod length checker and measure first, then place order for proper length pushrods.
Rocker arms, get comp magnums...180 bucks or so and very nice part roller design. Strong too.
Old 12-20-2010, 04:01 PM
  #73
VincentZ28's Avatar
Waste of money for street driving. On the dyno a gain of 2hp.
I looked up the cam you want to buy and that cam will not work for you. Its a carburator cam and you won't pass smog. XFI268 with springs will work fine.
Old 12-20-2010, 04:10 PM
  #74
VincentZ28's Avatar
In short dont buy that you dont really need. Just get the basic items for engine build.
  #75
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Do the Darts have EGR in the head or will you pull from the exhaust manifold like the vettes?
Old 12-20-2010, 04:16 PM
  #76
VincentZ28's Avatar
Yes they have them. 1989GTATRANSAM was using them and he pass smog with them.
Old 12-20-2010, 04:18 PM
  #77
cruzplcs's Avatar
Engine: 350 5.7
i look up the cam and i found a kit for 969.99 I just have to buy some 1.6 roller dont I?
KIT INCLUDES:
12-412-8 CAMSHAFT,
853-16 LIFTERS
2100 TIMING CHAIN SET
96986-16 Valve Springs
787-16 Retainers
601-16 Valve Locks
501-16 Valve Seals
202 Nylon Cam Button
7809-16 High Energy Pushrods
Instructions
Assembly Lube
Old 12-20-2010, 04:56 PM
  #78
Price: 570.99
Price:230.00
Price:531.99
keith black pistons
I would go with a champion radiator !!! + its a little cheaper !!
On the MSD, get a marine BOX..lots better less problems !!
Old 12-20-2010, 07:16 PM
  #79
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Its cheaper to build a 350 over a 383 and make the same amout of power.
How do you figure that?
The only cost difference on a full rebuild is the cost of the stroker crank and some labor for block clearancing.
Easier to make more Hp with 30 extra cubes as a base
Old 12-20-2010, 07:17 PM
  #80
Thats what i said, but ...oh well !!!!
Old 12-20-2010, 08:49 PM
  #81
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
What we found with the Stealth Ram is that you will lose lots of torque. We have one guy in SoCal with a Stealth Ram,......
Correction;
your comparison shows a SR will make more torque than a HSR
The torque/Hp profiles are already well documented in the previously posted EFI intake comparison
FWIW
I ran my fresh build 383 in with my proven big tube , fully ported ,siamized base TPI setup.
When I swapped to the HSR ,it was easier to launch because the terrible "loss of torque" helped me get traction off the line ( w/DR's) and the extra 1500 of usable revs at the top end made it run 4 tenth faster with no other changes
Old 12-20-2010, 10:42 PM
  #82
VincentZ28's Avatar
Well does andbody have proof that their 383 TPI made over 400whp with a TPI manifold? I'm using 400whp as a bench mark.
Old 12-20-2010, 10:44 PM
  #83
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
IF you run the same intake heads and cam on top of a 383 vs 355, the two are likely to make the same hp, but the 383 will make more torque. The 383 will just peak few hundred rpms sooner than the 355. If you go 383, you should go 5-6 deg more duration on the cam on both lobes to take advantage of the cubes. The increased stroke will require more duration. As long as the heads/intake dont restrict the air flow a 383 needs, you could see more hp but its not surprising to see same.
Yes cubes make more power but you need the induction package to use the cubes. I've seen this happen on a few LT1 builds... some of the "stage 3" 355 packages are equivalent to "stage 2" 383 setups...roughly same hp, but less rpm for the 383 and much more torque.
Old 12-20-2010, 10:54 PM
  #84
VincentZ28's Avatar
I think the problem is that a 383 is too much for a TPI unless you use a Stealth ram, Mini Ram or maybe the FIRST System. The most I've seen was a 406cu with a Fully ported welded up Super Ram, 280XFI and an old set of ARF's 195 behind a T5 Trans that made 403whp@5600 and 434wtq@4700.
Old 12-22-2010, 09:38 AM
  #85
cruzplcs's Avatar
Engine: 350 5.7
What is a Shop that i can send my TPI System to get fully ported here in Ca?
Old 12-22-2010, 10:48 AM
  #86
Stephen's Avatar
Car: 87 GTA
I think the problem is that a 383 is too much for a TPI.....
Nah. I wouldn't say that.
Seen a 383 long block with STOCK TPI base, runners, plenum & TB = 410hp/510ft lbs. Different intakes on the same engine increased HP & decreased torque. Sure would be fun in a street car.
Old 12-22-2010, 11:31 AM
  #87
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
ARGH!!!! What did I say in Post #6??? (hint...A L98 is a TPI)
If you put a STOCK TPI (intake, runners, plenum & throttle body) on a 383, with the right heads, cam & tuning, can get you 400+horsepower & 500ft lbs of torque. http://xtremecarzone.com.au/index.php?showtopic=386
Thanks for the TPI information web link Stephen
Old 12-22-2010, 02:34 PM
  #88
VincentZ28's Avatar
That article is Flywheel hp. I'm talking about RWHP!
Old 12-22-2010, 02:43 PM
  #89
Stephen's Avatar
Car: 87 GTA
Port work or bigger runners & that would take care of drivetrain loss, still be TPI & break 400hp at the rear wheels.
No need to lose TPI to get those rear wheel #s.
Old 12-22-2010, 02:54 PM
  #90
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
power adder?
Old 12-22-2010, 09:26 PM
  #91
Marv02's Avatar
Car: 1986 Vett, 2001 Expedition
Engine: 383SBC 435 H/P, 500 TQ
Axle/Gears: 307
LOL I have mild 357 in my 1986 vett it will run 12.7 in the 1/4 it has 307 posi rear end with 360 H/P 427Tq motor stuffed into it passes smog with cat back system.
Here the motor set up 350 bored .040 over makes it a 357 Hiper Flat Top pistons 9.575 to 1 compression, 4 bolt main not the stock block crank 10/10 Cam is a Howards 214/214@50 .447/.447 Lift with 1.6 Roller rocker arms that bing it to .479/.479 lift 290/290 duration 107 CL on the Intake 111 CL 16 degrees of cam over Lap Not a big cam RPM range 1000 to 5200, Eldenbrock hi flow tpi Intake Base, SPL runner, Trick flow super 23 heads with 195 runners 62cc, 24# injectors Chipped, Built 700R4 Trans 2200 Stall converter.
TPI engine are not High rev motors I set my up this way even if you had a 6500 RPM cam the TPI willnt rev that high, I think 5600 or 5800 I read is about Max.
It sound stock when it's running it a sleeper.
If you built the basicly the same motor with 383 and little larger cam you hit the 400 H/P easy.
If you put a Bigger cam raise the compression to 10 or 11 to 1 and run higher octain gas and higher stall converter you willing to rev higher also could get 400 H/P out the 355 motor.
But If I was you ang going to rev it alot go Forged pistons.
I can run Reg 89 Octain gas all day long drive it traffic get 27 MPG up on the HWY Suck all kinds of gas if you foot in it.
Turn the key and it will get you there every time with this mild motor set up and know one going to know you have something under the hood until it time to make them shut up.
Motor cost me $4500.00 to build the trans to get beefed up from a local shop with 2200 stall converter with a 1 year warrenty $1200.00 Installed.
If I was going to do it again I would went with a Roller cam set up I just did not want to spend the money at the time now I wished I did, as for the 383 yes and no extra 40 H/P would been nice.
Old 12-22-2010, 10:04 PM
  #92
Marv02's Avatar
Axle/Gears: 307
Oh yea keep this In mind it been proven lot of time maximum H/P not the best way to go useable power is what you want.
Power in the correct amounts at the right time will put out in front while the other guy with to much power that can't get to hook up is just burning his tires off going no where as you are pulling away.
Old 12-22-2010, 10:13 PM
  #93
__________________
357 4 bolt main (9.575 to 1) Balanced, Flat top 5cc pistons Howards cam 290/290 447/447 lift 214/214 @ .050 111 C/L, 1.5 RR Arms, Trick Flow Heads Super 23 (195 runners) 62cc , SPL runners Hi Flow intake base, 24# FIC Bosch 3 Injectors, Chipped.
700r4 Trans built, 2200 Stall Lock up Convertor, 307 rear end.
340 H/P 450 TQ
t’s not a racecar but never was built to be one.
Now that is a nice build !!!! me likey !!!
Old 12-22-2010, 10:34 PM
  #94
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
May I ask what the double post by two diffrent posters are all about? lol
Ohhhh now I see whats going on haha, much confusing...
And I gotta agree on the nice comment quote
Old 12-22-2010, 10:37 PM
  #95
I tried to quote him ..but it did not work 100% i guess..sorry
Old 12-22-2010, 11:11 PM
  #96
Marv02's Avatar
Axle/Gears: 307
Back In the day when I was heavy in to MX one of the top race teams said the same just because on the Dyno it makes the most power don't mean it the best motor set up to have.
Back in 1993 Honda Put Out the Honda CR250 it was not the fastest motor out they but it made the right amount of power at the right time thats why back there day they were King I keepped my Old 1994 Honda Untill 2006 And I still wish I keeped that Bike.
I had that bike for 12 years know one keeps a dirt bike for that long I had other bikes New bikes were purchased and sold after 1 year of ownning them while but I would not sell that bike.
Old 12-22-2010, 11:17 PM
  #97
I like when sombody understand this...
Dyno # dont mean a lot and a set up all depends on what u do with your car !!!!
Old 12-22-2010, 11:57 PM
  #98
Marv02's Avatar
Axle/Gears: 307
Why
If you want a motor build a Motor dont worry about the Bling Bling get the drive tran working before worry about the Bling.
Unless you planning a Hi reving Motor the Stock HEI system is good enough.
The Stock TB is good enough it can handle 700 or 800 HP
Throttle spacer waste of Money.
Why Dart Heads theres better out ther for the money take the money you save from the other unneeded stuff and buy Motor parts that makes Power Not the Bling.
If you go forged add anouther $500.00
What going to eat in to you buget is HEADS $1200.00 to $1500.00 intake base and runners $1000.00 Custom Chip $350.00 Bottom end $1000.00 to $1500.00 Roller cam rockers arms push rods $1000.00 FIC Injectors $250 there's $4750.00 In parts already.
Plus trans to handle the New power Dont but a E-Bay trans you look at at Least $1200.00 up to $2500.00
Plus Trans Cooler $40.00
So far your up almost $6000.00 not including labor unless you doing your onw rebuild.
Not counting on all the hidden cost Oil Coolent Gaskets Ect Set anouther $500.00 to the side just in case.
Price: 570.99
Price:230.00
Price:531.99
keith black pistons
Old 12-23-2010, 12:51 AM
  #99
cruzplcs's Avatar
Engine: 350 5.7
do i have to ported the heads to or just the intake and runner and plenum?
Old 12-23-2010, 02:05 AM
  #100
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Put some good valve springs on these to suit your cam and you are still ahead in $$$ over the Darts
Price is for a pair
http://www.summitracing.com/parts/TFS-30400001/
Quick Reply: Trying to upgrade my 350 TPI Engine
