EGR cause stalling?
EGR cause stalling?
I have a 91 formula withna 350. The runs fine when cold but when warm it stalls around 1000 rpm and hunts for idle. Sometime it goes away and runs decent when warm. It is throwing the erg code. Is the egr causing this issue?
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: EGR cause stalling?
Probably a problem with the EGR valve. Do a search on here and find the troubleshooting method.
Hope this helps.
Hope this helps.
HoosierinWA
10-07-2015 10:15 AM
