bosch 3 injectors . need help.
Car: 1990 FORMULA WS6 T-TOPS
Transmission: BORG-WARNER T5
Axle/Gears: BORG-WARNER 3.42
My friend just bought the bosch 3 injectors from southwest fuel injectors. after the installation the car sounded worst and felt very bad. the car smells like a gas station , misfires, and stalls alot. it stalls when you try to reverse the car. the engine shakes as we increase speed too. can someone help please. the car is 1990t/a 350. does anyone have pics of the injectors in the engine installed already.
Re: bosch 3 injectors . need help.
this are 22lbs. stock. no tune needed.
Never heard of Southwest Fuel Injectors, and I googled them and nothing even came up. Is this some EBAY company or something like that? If it wasn't from a reputable re-builder, they could be junk. I'll send you a set and you replace them. If it doesn't work, I'll take them back.
If you want me to flow them send them in I'll tell you if they work.
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
I'd guess if it smells like gas and runs like ****, they are leaking.
Take Injectors Plus up on their offer regardless IMO.
i meant southbay fuel inject..
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello pestrada38!!
Give southbay fuel injection a call, and explain the problem to them, since that is where you got the injectors from, give them the chance to help you out, it's the least that you can do!!
I believe that they have a 3 year warranty, so, you have nothing to lose!!
P.S. Did you disassemble the fuel rail, and maybe got an o-ring twisted/split/pinched in the process?
or as per southbay's site.
"INSTALL INJECTORS INTO INTAKE MANIFOLD FIRST, THEN THE FUEL RAIL FOR PROPER INSTALLATION & FITMENT !!!!!!"
SouthBay Fuel Injectors
516.492.6504
516.492.6504
are the old injectors supose to come out from the manifold with the orings in tack on the injector. i think maybe the old orings are stuck in the manifold thus causing the leak.
Hello pestrada38!!
I had people here all day and I'm cleaning up. I know it's Thanksgiving, but if you want PM me and I'll send you my home number. It will get me out of cleaning up...
516.492.6504
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Put a vacuum gauge on the engine and see what it is saying. should be 15-20 In of mercury
Yep, see if they can provide you some tech support and give them the chance to solve the problem.
I don't think that's the issue. He would see leaking all over the place if he installed them wrong, as soon as the fuel pump is primed.
The OP did say "are the old injectors supose to come out from the manifold with the orings in tack on the injector. i think maybe the old orings are stuck in the manifold thus causing the leak."
To me, this means he has a leak, he said so himself, and he smells gas, and possibly a vacuum leak as well, causing his car to run like crap!!
Hello pestrada38!!
If I were you, I'd re-do the job, and make sure that your o-rings are sealing correctly, and only use new o-rings!! Depending on how far you took apart the plenum, and runners, check these parts for vacuum leaks also!! If you got the injectors with the adapters, they only require one o-ring on each end!! Make sure when you removed the old injectors that you got all the old o-rings out of the manifold, and the fuel rail!!
Lastly, give southbay a call!!
Hello InjectorsPlus!!!
Think about it, the fuel pressure is coming from the top, not the bottom, the only time there is fuel in the bottom is when the pintle moves. Only a defective injector can leak from the bottom. I AM NOT SAYING THAT IS THE CASE, but in terms of troubleshooting, he needs to understand what he's looking for and not look for things that don't happen.
Think of it as a hose bib. The pintle being the valve. The only way it drips is if the valve is defective. A good valve can not leak so if there is water puddling it is leaking before the valve. Same thing.
Let's give SB a chance. I get on the phone with customers to work through problems like this all the time, I'm sure she'll do the same. It's time consuming, could take an hour or more, but helps customers. She'll help him figure it out, vacuum leak, injectors, whatever I'm sure the problem will be solved. That's what good vendors do. I find conversations solve problems better than postings, call them. Good luck Pastrada!
Ok everyone, just got online...was away for the holiday....i see that there is an issue here. First of all, thanks 87iroc-dan61,,, second of all if anyone ever experiences a problem with our injectors we are the ones that need to be contacted---it is our product and it is our responsibilty to take care of any issues that may arise.
Injectors plus, i was the one who made the comment about a leaking injector. I said that if an injector leaks from the rail, it is due to improper installation or an oring issue. If the fuel is leaking from the rail side it is not an indication of a faulty injector,,,if the injector itself is going to leak, then it will leak from the bottom.
Providing good customer service does not end after the sale,,,we are here to help for as long as you need us.
pestrada38,,whenever you remove injectors from a fuel rail and intake, you always need to make sure that both upper and lower orings come out with them and that nothing is left behind.
If you are having a problem please give us a call.
Hope everyone had a nice Thanksgiving!
ok well i need some new or rebuilt injectors. for a 91 z 350 . im looking for a good bang for a buck. im realy low on cash but i would want some good injectors . im in los angeles. does anyone know were i can get them or get mine rebuilt for cheap in s cal
UMMMMM......201-258-5600. You can call till 8PM your time, 11PM mine.
I'll give you a good deal, and we have the best product in the market, in my humble opinion.
Hey pestrada38,
haven't heard from you and haven't seen any updated posts.
Were you able to figure out what the problem was? Is your car up and
running yet? Once again, if you have any questions or if we can help in any
way please contact us.
www.southbayfuelinjectors.com
516-492-6504
516-492-6504
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
I know this is an old post but I was wondering what the turnout was.
I also purchased the Bosch 3's and was wondering the best way to install per instructions "install in the intake first" I'm also trying to figure out the best way to clean the fuel rail ports that the inj are inserted into.Whats the best tool to use as I dont wanna damage the aluminum.Thanks guys
Car: 1991 Trans AM GTA
Transmission: 700r4 (for now)
BumpaD82
02-26-2016 02:57 PM
