1986 305 TPI, Stock Heads: Thoughts on the Crane 2020 Cam over the STOCK PEANUT?
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Hi,
I am continuing to tear down my stock 1986 305 TPI, and getting ready to buy my upgrade parts.
A local parts shop recommended the Crane 2020 Cam as a good replacement for the stock cam, when used with the stock heads. I am looking for a bit of extra performance over stock, particularly on the low-end (stop light to stop light, the on-ramp, etc).
**** I also see this cam advertised on CompCams website: part number 12-388-4, grind number 252AH-12. Anyone have input on this one? Seems close to the above Crane cam.
Any thoughts? THANKS!
Engine: 5.0 LG4
Re: 1986 305 TPI, Stock Heads: Thoughts on the Crane 2020 Cam over the STOCK PEANUT?
Interesting...I spoke to someone at CompCams, and they have also recommended the 12-388-4 cam for me. I have also called my local parts guy, who seems to be quite experienced in this area, and he is looking into it for me.
I will let you guys know what I find out, and what I end up buying. Again, if anyone has thoughts, please do share.
*** FYI, here is the Comp Cam that I am probably going to buy:
http://www.compcams.com/Company/CC/c...?csid=125&sb=0
Engine: 5.0 LG4
Specs from Comp Cams on the 12-388-4. You can view it better at this link though; http://www.compcams.com/Company/CC/c...?csid=125&sb=0
PART NO. 12-388-4
01 INTAKE MASTER 5200
02 EXHAUST MASTER 5211
03 ENGINE CS 252AH-12 (V-8 T.P.I.)
04 GRIND NUMBER CS 252AH-12 (V-8 T.P.I.)
INT EXH
05 HYDRAULIC Y/N YES 14 DUR @.050
206 212
INTAKE EXHAUST 15 LOBE LIFT
.2830 .2930
06 VALVE ADJUSTMENT HYD HYD 16 ROCKER RATIO .00
.00
07 MAX GROSS VALVE LIFT .425 .440
08 DUR @ .006 TAPPET LIFT 252 260 17 LOBE SEPARATI 112.0
18 ADVANCE 4
09 VALVE TIMING OPEN CLOSE 19 VALVE SPRINGS 981-16
@ .006 10 INT 18 54
11 EXH 66 14
12 THESE SPECS ARE FOR CAM(S) INSTALLED
@ 108.0 INTAKE CENTERLINE
Engine Family:Chevrolet 262-400 c.i. 8 cyl. 1955-1998 Description: Hydraulic-
Cam Family:Computer Controlled Hydraulic Flat Tappet Camshafts Specifications IntakeExhaustRPM Range: Valve Lash: Valve Timing: Duration: Lobe-Center Angle: Duration @ .050" Lift: Intake Centerline: Valve Lift: Lobe Lift: Valve Timing @ 0.006 Lift: ExhaustCloses14 ATDCOpens66 BBDC108 Intake 18 OpensBTDC54 ClosesABDC
PART NO. 12-388-4
INT EXH
206 212
.2830 .2930
.00
18 ADVANCE 4
@ .006 10 INT 18 54
11 EXH 66 14
Last edited by Looksthakill; 11-10-2010 at 07:00 PM. Reason: Added details for cam...
1 Post
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
I like Crane's 2030 for your car.
Car: 1969 SS
Engine: RamJet502
Transmission: Richmond 6 Sp
Axle/Gears: Currie, Eaton, 3.91
I am going to purchase the Compcams 252ah-12, I have installed a 406 SBC with 113 heads into my Jeep with a stock 1987 camaro TPI and 24lb Ford SVO injectors. Looks like the best cam for the torque I am looking for and the range I drive in. It has nothing over 4500 though. I ran a simular 252ah-8 in a full size blazer with a HO305 out of an old rusted Trans-am and it pulled like the dickens even though the blazer is about as arrow dinamic as a bread box! Great milage but again not much for anything over 4500...If you are looking for torque and fuel economy in a daily driver I believe you will be very happy with 252...remember the TPI stands for Tuned port so you need run a cam with around 202 dur and 112-116 lsa for the proper tuning to occure or it will fall flat on it's face...my 2 cents...
