Heads/Cam/Intake upgrade?
Hello, my cousin and I are looking to get the maximum performance out of his 5 speed iroc Camaro with a 350tpi, swapped from the original 305. I was thinking we could do a nice top end upgrade to Edelbrock tpi base, runners, and top manifold. Also a set of the Performer RPM Heads and an appropriate cam to go along with it. The motors pretty much stock except for Edelbrock headders and y-pipe and MSD Igintion upgrades.
What Im basicly asking is what is working well for you guys? Will this even be worth the trouble?
Thank you for your time. RD
Re: Heads/Cam/Intake upgrade?
there is a wealth of information on this site man all you have to do is search and read. im not trying to be rude, but there are hundreds of answers for you, and tons of guys have done similar things, also it all depends on what your goals with the car in the end
1 Post
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
I just built a budget 355 using edelbrock e-Street heads, comp cams 08-305-8, holley 52mm throttle body, PRW Roller rockers, and lots of other inexpensive parts. Its all backed up by my T5 too. Lots of fun on the street, about to take it to the track in a couple weeks. Just learned how to tune as I went from factory non-cc carb to TPI!
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
for a stealth ram you would be now making most of the power up high. Recommend a better gear ratio now like a 373, so you can get up there faster to your new rpm range.
1 Post
Axle/Gears: 3:42
watch out for duration on the cam. Too much and you will need a prom reflash.
1 Post
Axle/Gears: 3:42
The Afr 180 is a 180cc intake runner. Edelbrock is a 165cc which will give you more low end torque. I would keep the car true to it's low end torque.
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
I have made the following upgrades to my otherwise original L98 350:
CC XR258HR-12,Trick flow heads 195cc,Edelbrock baseplate unchanged,SLP runners siamesed,original plenum siamesed,Hooker 2055 headers with 3inch Y-pipe,3inch fullflow Catco,American thunder after cat system,March pullies,Accel 24lbs injectors.
Despite not tuned(running lean)and the cam is to small and the heads are to big yes i know but car still pulls really strong.
regards Mats
regards Mats
dbrochard
09-25-2015 04:56 PM
