why is my 88 iroc-z not firing?
Old 08-19-2010 | 11:50 AM
jemarcusray's Avatar
i have new coil and everything put still no fire someone please help. distributor and the cap twice and the coil three times but still nothing its getting fire to the coil but not pushing out and its grounded
Old 08-19-2010 | 01:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: why is my 88 iroc-z not firing?
What does "getting fire to the coil but not pushing out and its grounded" mean?
Old 08-19-2010 | 03:15 PM
it not firing (the coil)
Old 08-22-2010 | 04:36 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Bad ignition module or p/u coil.
Old 08-24-2010 | 01:07 PM
i change the pick up coil and the ignition module
Old 08-24-2010 | 01:23 PM
racethesunlive's Avatar
Car: '92 Camaro
If your not getting spark from your ignition coil to the distributor, try unplugging the 4-pin connector going to the distributor ICM and check for spark. If you have spark with the 4-pin connector unplugged you have a bad Ignition module. If your still not getting spark check for 12v going to the coil at key-on and also make sure the coil is solidly mounted.
Any codes being set when you try and start the car?
Old 08-25-2010 | 09:09 AM
its firing now but something is wrong with the fuel pump relay now, new fuel pump and relay
Galaxie500XL
02-01-2020 04:53 AM
RS Reaper
10-17-2018 07:52 PM
88CamZ
10-08-2015 10:29 AM
SS-EXPRESS
09-28-2015 09:14 AM
indygene
09-26-2015 11:21 AM
Quick Reply: why is my 88 iroc-z not firing?
