what can be done to the STOCK tpi runners?
1 Post
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
as the title says...
what can i do to my stock runners to get better flow?
can siamesing only be done with aftermarket runners or what??
Mikey
Mikey
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: what can be done to the STOCK tpi runners?
They can't be ported, the walls are way to thin, but you could cut the runners and then weld two of the runners together and make them turn out like the SLP's. I think that would be more work then it's worth.
1 Post
Engine: 5.7 350 TPI
it would give me something to do :P lol..how would i go about welding them?? use sheet metal to put em back together?
Car: Firechicken
I would try my luck with aluminum and get so Argon. You could try sheet metal but the casting of the stock runners is SUPER THIN, and welding to it might not be a great idea in the first place.
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
Supposedly you can use the material in the housing off of an onboard computer as the metal. I have seen pictures of this (from this site) and it looks doable. Has anyone tested this runner to see how it compares to aftertmarket runners? I have SLP's on my car and have considered this method myself.
Car: 87 GTA
Stock runners can be sent off & have Extrude Hone hone the insides, which also results in a very smooth interior wall.
Siamesed stock runners has already been covered.
But don't forget the bottom intake base & the upper plenum. They can also be ported. Extrude Hone can do the lower & a Dremel tool can be used for the upper plenum.
1 Post
Engine: 5.7 350 TPI
sweet cant wait to do this...gahh..haha
gonna do a search for siamesed stock runners now..
I dont know if it works but Ive heard about filling the runners up with water and then putting them in the freezer. When the water freezes its supposed to stretch out the runners as it expands.
Car: 87 GTA
But for it to work, both end has to be capped, with only a small hole left for the water to expand out. Too small & it could rupture the runner. Too big & it will just expand out & not push against the dents.
1 Post
Engine: 5.7 350 TPI
couldent find any threads about successfully siameseing these,,,,
SLP Runners are $329.95 right now. Just bite the bullet and buy them.
1 Post
Engine: 5.7 350 TPI
nah..too easy..ima buy a set of crap runners and try it..
Mikey
Mikey
Car: 87 GTA
400hp/500lb fts is pretty easy on stock top end parts. After that, the dollars start going out faster than the hp/ft lb numbers come in.....And it retains a stealth profile. "Yep, its a mostly stock TPI. Wanna run?"
And those #s make for a GREAT street car and light to light challenges.
1 Post
Engine: 5.7 350 TPI
yeah lol..next mod is heads and cam so i should be alright
1 Post
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
There is a thread about doing this on a corvette forum. They show the process and tell what they used.
Go:
http://forums.corvetteforum.com/c4-t...unner-mod.html
Tell us how it turns out, im all for diy cheap hp.
Go:
1 Post
Engine: 5.7 350 TPI
thats EXACTLY what i wanna do! mos def doing it...
1 Post
Engine: 5 Liter 305
Axle/Gears: 3.45
I think this is a good idea for someone who doesnt have the cash, but in all honesty, its a crap shoot as far as quality and time spent for the performance. Dont get me wrong, I think its cool to do your own runners, but if someone is going to make some runners, someone needs to make some short, fat runners somehow, turning the TPI into "RPI" Ram Port Injection.... kinda like the 1st fuel piece, if not JUST like it, for cheap.
Any takers??
Any takers??
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
here is what i have done. i sold these a few years ago
Car: 89 Iroc
How does the power/ and power band compare to aftermarket runners?
Engine: 5.7 HSR
i never had these on the car sold them because i went a different direction with fuel injection.
1 Post
Engine: 5.7 350 TPI
see i like the way that looks and even if the improvement is small i wanna do it...
Engine: 5.7 HSR
i have an intake that i started to mod for sale if interested.
Car: 89 Iroc
I am thinking that this type of runner may perform very well. UNfortunately I have never found comparisons to the common aftermarket runners such as SLP/Edelbrock. Since they are fully seimesed they should move the power band up.
1 Post
Engine: 5.7 350 TPI
thats the goal...tryin to do this so i dont have to pay $300+ for aftermarket ones..
1 Post
Car: Lots of 'em
Invest in one of these, and you will not have to worry about the crappy flow of the stock runners for a good while.
It'd defeat the purpose of not wanting to spend $300+ since most Turbonetics GTK's are over $2,000 each, but hey, what can you do.
1 Post
Engine: 5.7 350 TPI
lol...well this "project" with my runners wont cost me a dime as im gonna be doing it in my shop class once school starts
1 Post
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
If you want a project, put a slit down each runner tube on the outside, down just one half. put a slice down half of the top, and port it open to 1.6" ID leaving the bottom alone, then run a steel ball down the tube. Tack weld some sheel aluminum back over the tube while the ***** are inserted, remove the ***** and close up the welds. Should work well for a 350. Go with a 1.65" ball for a 383.
Note that runner length will slightly increase if you do this to the outside of the runner (if they were installed on the engine) and decrease the length slightly if done on the inside.
Done right, it works, and someone good with aluminum can hide the fact that they were modified. This is how I size runner tubes to different engine combos since different engines and combos require a little different intake prep. Weld it, grind it down, sandblast it and paint it in aluminum cast coat and clear it. They will look new and unmodified, just larger. The hard part if working out those bumps in the tubes to clear the bolts... that part was a PITA! I just weld up around the stubout on the bottom of the runners and port the inside to remove those before running a cross buff on a flex shaft through the runner and base (bolted together).
Damn I need to open up a TPI shop lol
1 Post
No, but maybe I should do a writeup when I get back. I'm in Iraq right now and the pics are on my external at home.
I'm planning on doing a set in 1.66" for my trans am thats about to get a 383 and another set for my 427ci TPI project engine. The larger set will be done in 1.75 and requires splitting both sides making it alot more complicated.Runners can't be opened up like this much more than 1.65" without risking a compromise in gasket material and sealing ability along the top half of the runners where they meet the plenum.
1 Post
Engine: 5.7 350 TPI
ahh i see..well lemme know when you get that done thanks
Mikey
getting back in the shop 2marro so we'll see how this goes..
Mikey
If your going to be working on this in your shop class why dont you spend the money on some SLP runners and do what Kevin and Don did to theirs. It would be really cool to say you did it and it would look BA.
1 Post
Engine: 5.7 350 TPI
i dropped the class so i wont be doing this anymore the class got a different teacher that didnt know a socket from a wrench...he asked me what i ment by "my car has a 350" O.o lol..so i dropped it....
Mikey
Mikey
1 Post
Engine: 5.7 350 TPI
ehh...i switched out already..ive taken that class 4 times already so im good..im taking Virtual Enterprise now so i can get some business experiance
Mikey
Mikey
1 Post
Engine: 5.7 350 TPI
i know you want the post count but MODS PLEASE CLOSE. thanks..
#42
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
um no, im an little to mature to do that on hear, its that you were all into doing this and then all of sudden you decide to quit the class (not that im saying you shouldnt of) it's just kinda funny how things change so fast...
#43
1 Post
Engine: 5.7 350 TPI
whats funny about it? the teacher changed therefore i didnt want to have to do all the book work again, establish a good enough relationship again with the shop teacher so he would let me bring my car, and i didnt want to put up with having this guy ask me what something is when he should know because hes the teacher. also, i switched classes because the class im taking now is a course about entrepreneurship so after this class ill have at least SOME experiance with business and this played out in my favor anyway. BUT at any rate, id love to still do this, i just dont have the resources for a welder, grinder or dikes.
Mikey
Mikey
Sanjay
08-12-2015 03:41 PM
