The project wont pulse at injectors
Old 07-25-2010, 12:43 PM
Prostreet87Z's Avatar
Car: 1987 Camaro Iroc-Z
Engine: 5.7L 350 TPI
Transmission: Manual Valve body TH 350
alright so this is my history. 1987 camaro iroc used to be 305 tpi i put a 350 into it and had to get a new wiring harness. its been all pulled apart for a while i just got it back together. i got a msd street fire box, AC deleted, egr is in place but not connected, rest of the emission system is gone, fuel pump relay for what ever reason was hacked off this harness so i got the fuel pump hot wired to a switch. it all ran before as it is minus the newer harness. the only reason i got a new harness is because my fuel pump wouldnt turn on i had to hotwire my pump anyways.
car cranks fine, spark is fine, 45psi at the rails, injectors are getting 12v constant with ign on, all injectors ohmed at between 12-12.5 these are LT1 injectors, i have a spare ecm ive tried both with no flash on my timing light when i hook it to an injector wire, the connectors on my dizzy are all hooked up but i havent tested the dizzy at all not sure how to double check those but it did run about a year ago with the same one.
any info on how to test the pickup coils and stuff would be cool . i do have a few wires behind my engine just hanging out but i figured they are emissions or ac related.
please help! ive been working on this thing for 2 years and havent drove it out of my garage im about ready to turn it into scrap my motvation is running out!
the pictures i added in here are of the spare connectors and my wiring setup i removed the plug wires to try and find loose wires easier.
Old 07-25-2010, 12:57 PM
Re: The project wont pulse at injectors
id like to check and see what reading im getting out of my distributor anyone know what kind of voltages i should be getting in and out of the 4 wires leading to my ecm?
Old 07-25-2010, 06:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Is TPS set correctly?
High TPS Volts while cranking will shut off injector pulse.
Really need to pull the codes to see if any spark /ESC related ones showing
Also injectors should ohm out closer to 16
Old 07-25-2010, 08:23 PM
is that for all injectors though? all these lt1 injectors stayed pretty close together within half an ohm. ecm is not giving me any codes i dont see anything on check engine and i did set the tps correctly and its got good response during operation
GeneralIesrussi
Carburetors
06-20-2024 07:21 PM
buffaloman
Firebirds Wanted
09-07-2015 09:47 AM
buffaloman
Camaros Wanted
09-07-2015 09:46 AM
SG91camaro
09-05-2015 10:27 PM
rudolphschenker
09-04-2015 02:41 AM
Quick Reply: The project wont pulse at injectors
