FUEL INJECTORS
Car: 1990 TRANS AM GTA
Engine: L-98 350
Axle/Gears: STOCK GM 10 BOLT
FUEL INJECTORS
I CHANGED MY STOCK FUEL INJECTORS WITH A SET OF TRICKFLOW 24LBS/HR PART #Tfs-89024 NOW IT WONT START OR WHEN I DO GET IT RUNNING I HAVE TO BE IN AND OUT OF THE THROTTLE AND RPM IS GOING UP AND DOWN, ITS A BONE STOCK 1990 TRANS AM GTA WITH THE L-98 350, OH AND NO VACUME LEAKS
Re: FUEL INJECTORS
check the fuel pressure
Engine: L-98 350
Re: FUEL INJECTORS
yea its at 40psi, new fuel pump and filter
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: FUEL INJECTORS
It could be that 24 lbs/hr is too much. I think the stock injectors flow 19 lbs/hr. If it ran fine before you changed them then that's probably it. Try putting the stock ones back in and if she runs fine with the old ones, there you go.
Re: FUEL INJECTORS
Bingo! Im afraid jtsk is right. Unless youve made changes to the motor to increase its fuel requirements, larger injectors are not going to work.
Engine: L-98 350
Re: FUEL INJECTORS
yaeh and it ran like s*#@t with the stock ones not enough ohs of restance, would a dyno tune be able to adjust the ecm so it could run
New2Chevy
10-04-2015 11:27 PM
Firechicken86
08-12-2015 10:07 PM
