86 camaro TPI non serpentine alternator bracket
Car: 1986 IROC
can anybody send or post pics of this?? also any ideas where i can get an alternator bracket?? no local parts stores have one for the TPI setup, nor do any of the junk yards, i am getting very frustrated. I have a bracket that i bought from o'reilly auto parts, but there isn't enough room between the top bracket and the bottom bracket. the alternator wouldn't fit. anybody have any suggestions on what i can do?? could i possibly buy a smaller alternator??
Car: 1986 IROC
Engine: 355" TPI
Re: 86 camaro TPI non serpentine alternator bracket
The one you have is probably for a carb engine. I think you should be able to use it if you remove the back mounting tab and just use the water pump and alternator holes. That should allow it to fit.
Car: 1986 IROC
Engine: 355" TPI
I cant get a good picture of whats on the car right now. I found this picture and have a line showing where to cut it off. This is what I remember doing back in 05 when I rebuilt the engine. Hope it works for you.
Car: 1986 IROC
i figured that was what you cut off, i will try it when i can, hopefully soon, thanks a bunch.
Car: 1986 IROC
yeah that bracket looks just like the one i bought, mine is chrome, got it off of classicindustries.com, the top tab would bolt to the intake, but the bottom tab was nowhere near a bolt hole on the water pump. the other one i have bolted up just fine to the water pump and intake, but the alternator wouldn't fit between the brackets.
1 Post
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
I've got one if you still need one. I switched to Serp, so I no longer need it. $30 shipped in lower 48. Just PM me.
1 Post
thedrewdotcom, you have a PM from me.
Edit: I checkd the PM's, but it doesn't show the one I sent on Wed, or the one I sent today. Send me an email at m_darby@yahoo.com.
Car: 1986 IROC
sorry i have been busy lately and haven't checked the board, i PM'd you though, check is in the mail.
1992 Trans Am
05-10-2023 07:19 PM
rh76camaro
08-15-2015 12:48 PM
Sanjay
08-12-2015 03:41 PM
db057
08-11-2015 10:11 PM
