tpi stumble
Old 03-19-2010 | 06:20 PM
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
tpi stumble
hey guys i could really use some help before my dad dumps more uneeded money into his car ....its a 86 iroc 305 tpi auto the problem is it is stumbling under acceleration and hesitates when you rev up ..we have changed throttle positioning senser and brand new maf senser next step is going to be a tune up (plugs wires cap rotor) but is there anything else that could be killing us..PLEASE HELP! thanks guys
Old 03-19-2010 | 07:10 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
Re: tpi stumble
pull the ign control module out of the dist. and have it tested at autozone. if it fails, you found your prob.
Old 03-19-2010 | 08:18 PM
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
Re: tpi stumble
tyvm i will try in morning...sounds very possible
Old 03-21-2010 | 10:14 AM
justbecause8286's Avatar
Car: 82 Z28 86 Iroc
Engine: 400 +.020 305 TPI
Transmission: 700 R4
Re: tpi stumble
Hey, This is slowmaro's dad. I changed ign module w/new new cap, rotor, wires and E3 plugs. Still have stumble/hesitation problem. I'm at the frustration level now. Any further help would be great! Thanks
Old 03-21-2010 | 01:48 PM
Pontiac400's Avatar
Car: 90 GTA, 72 Chevelle, 76 GrandPrix
Engine: 350TPI, 383, 400
Transmission: 700r4, Th350, Th400
Re: tpi stumble
Have you ohm checked your injectors I was having the same problems and 3 of my injectors were weak and 2 were totally bad.
I did all the same things cap, rotor, wires, ignition module, spark plugs and it still ran the same new injectors fixed it all.
Old 03-21-2010 | 06:30 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: tpi stumble
Check your timing recently? Some more info on what's been done recently would help, and when/why this problem started in the first place. You can throw parts at it all day, might be something simple like a ground, I'd check all the bases first before buying anything else.
Winchester1094
08-18-2015 10:23 AM
mdtoren
08-16-2015 05:45 PM
Sanjay
08-12-2015 03:41 PM
squiggy2
08-09-2015 09:30 PM
Quick Reply: tpi stumble
