Can you replace the hard lines off the fuel rail hard line with flexible lines?
1 Post
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
So I bent my first hard line off the fuel rails hard line. And I have a deadline of a few weeeks to get my GTA going. Does anyone know if you can replace those 2 with a new flexible fuel line..
Here's some pics.
Or if someone has this line that I need and wants to sell it that would be great!
I only need the bottom one, not the pressure line, the one with the smaller opening.
Thanks guys
Here's some pics.
Thanks guys
Car: 88 IROC Z
Engine: 5.7
Axle/Gears: 3.27 9 BOLT POSI
Re: Can you replace the hard lines off the fuel rail hard line with flexible lines?
YOU CANT USE REGULAR FUEL HOSES. FUEL INJECTION IS TO MUCH PSI. YOU CAN TAKE IT TO A HOSE SHOP THEY CAN MAKE IT FOR YOU. I DID THAT WITH MY 84 GRAND NATIONAL. IT'S A HARDLINE WITH A FLEXABLE HOSE IN THE MIDDLE AND I COULDN'T FIND IT, THEY WERE THE ONLY ONES THAT COULD FIX IT.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
No need to SHOUT
System is nominal 45psi operating pressure as set by reg, may spike to 70 psi
You need the correct adapters to fit the rail and other end and either run AN fittings and s/s braided line or use 250 psi injection hose with barb fittings (cheaper )
Metric O ring to -6AN Fuel rail adapter
( check size first , some cars have 14mm on return line)
http://www.summitracing.com/parts/RUS-648060/
AN Barb fitting for push on hose ( need box cutter to get hose off after fitting )
http://www.summitracing.com/parts/AER-FBM1512/
Hose ( many different brands ; just make sure it is rated to 250 psi )
http://www.summitracing.com/parts/AER-FCV0610/
