Is my tps bad?
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Is my tps bad?
Ok so heres the deal. When I hit the gas the car takes off slow and stops accelerating past about 2.7k rpms. I checked the voltage on my tps, at idle its reading the correct .54 volts. However at WOT its only showing 3.2 volts instead of the ~4.5 volts it should show being at WOT. Is there anything I can adjust to fix this or is this a prime example of a shot TPS?
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Is my tps bad?
sound like you need a new one to me, they are not expensive, it should be reading higher at WOT. Do you have a 5 volt reference on the other pin with key on?? should read right around 5 volts all the time, if that's good, then replace TPS I would say.
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Re: Is my tps bad?
Yes I am getting 5 volts on the other reference wire. I will pick up a new TPS tonight and give it a try.
BumpaD82
02-26-2016 02:57 PM
MikkoV
09-09-2015 04:25 PM
